Old Feb 7th, 2008, 03:26 PM   #1 (permalink)
RogerB
94 Maxima stereo problem
I am a new nissan owner. I just bought a 1994 Maxima with 68000 miles. There are a few problems but I hope ya'll (yes I am from Texas) can help me. The Bose stereo does not work. If you turn the volume up all the way you can hear a very faint sound out of one of the speakers. I replaced the stereo with a JVC and now I cannot hear a thing. I am 99% sure I hooked the wiring up correctly after purchasing the harness and the antenna adapter. Any suggestions
RogerB
RogerB is offline   Reply With Quote
Old Feb 7th, 2008, 04:12 PM   #2 (permalink)
internetautomart
Flat 4, you know the Scor
internetautomart's Avatar
you probably have bad amps.
the factory bose system had each speaker amplified seperately.
the best option is to put in new speakers and bypass the amps entirely.
the original speakers don't get along well with most aftermarket radios.
Maxus 2008 will be in Chicago in June
All are welcome
Maxus is a gathering of Nissan Maxima enthusiasts from all over the continent.
Old Feb 29th, 2008, 07:49 PM   #3 (permalink)
i r teh noobz
Nissan Fanatic
i r teh noobz's Avatar
Sorry to thread-jack, but I also have a bose stereo problem. My sister's '92 will just make a loud (very loud) hum from the speakers when the stereo is on. It plays no music.
i r teh noobz is offline   Reply With Quote
Old Mar 1st, 2008, 04:24 AM   #4 (permalink)
MyGreenMax94
Think before posting
MyGreenMax94's Avatar
Again, Bad amps..
I suggest replacing the whole shabang with aftermarket equipment.These old systems are simply not worth trying to save.
MyGreenMax94 is offline   Reply With Quote
Old Mar 1st, 2008, 01:10 PM   #5 (permalink)
i r teh noobz
Nissan Fanatic
I'll let her know. Thanks.
Will a harness adapter work if I replace the speakers, or do I need to cut the existing harness?
Old Mar 1st, 2008, 06:16 PM   #6 (permalink)
MyGreenMax94
You can cut the amp/speaker plugs off, then use the two smaller wires of the for your aftermarket speakers, i cant remember which ones are the positive/negative, it's been a while since i done it.
Or you can just run new wire for the front/rear speakers, which ever is easier for you.
I recommend using the scosche wiring harness adapter for any aftermarket head unit. These are usually available at walmart.
WIRE HARNESS LINK, CLICK HERE
Old Mar 1st, 2008, 08:02 PM   #7 (permalink)
internetautomart
I reused my harness from car to amp to make hooking up the speakers a click and done dealio. made it much easier to install.
I always prefer harnesses to connecting wires directly.
All are welcome
96 Maxima Electrical problem jaschlicht A32 1995-1999 Chassis 3 Aug 26th, 2007 01:47 AM
2001 Maxima - Problem with engine light Sheila Tonini A33 2000-2003 Chassis 4 Sep 10th, 2005 09:11 AM
1993 Maxima car stereo questions: Active sound? Tf0r1 J30 1989-1994 Chassis 4 Jun 21st, 2005 09:59 AM
96 Maxima Bose stereo help please... OneBadLT123 Audio 7 Jul 21st, 2004 02:42 PM
90 Nissan Maxima dash problem fatboyvegas2002 New Member Forum 0 Jan 5th, 2004 09:57 AM
