Old Feb 3rd, 2008, 05:55 PM   #1 (permalink)
93max93
Tapping sound from engine:
Hi,
I bought a 93 nissan maxima a few months ago that could be mistaken for a show room car. It only has 70k origonal miles.
The car did have an injector issue so I had to replace them. I did a motor flush and I use nothing but royal purple now.
I only have one issue now. There is a tapping sound comming from the engine as soon as I place it in drive. Its loud enough to here it from inside the car.
When I'm in park it goes away but as soon as I put the car in drive or accelerate up steep grades it comes back again.
What Can I do to fix this? I mean can I buy new rods and lifters because the valve covers are easley eccessable
93max93 is offline   Reply With Quote
Old Feb 6th, 2008, 09:23 AM   #2 (permalink)
internetautomart
Flat 4, you know the Scor
internetautomart's Avatar
I assume you have the 24 valve motor.
if so:
it's the VTC assemblies making noise.
you can us a better filter (toyota OE V8 one) that has am amti-drainback valve in it. you can also ground out the VTCs as well. I suggest doing the oil filter and seeing if that works for you, it has for a lot of people.
Maxus 2008 will be in Chicago in June
All are welcome
Maxus is a gathering of Nissan Maxima enthusiasts from all over the continent.
2003 Altima 2.5s engine DESTROYED from loose Power Valve Screws. lax26grad L31 2002 - 2006 21 Mar 12th, 2007 01:57 PM
Tapping Sound Under Timing Belt Cover ZXguy1986 Z31 300ZX(T) 4 Mar 4th, 2006 03:00 PM
Instructions and the step by step of swap BobbyRay S13 240SX 1989-1994 47 Dec 22nd, 2003 10:09 AM
Shaking Sound from Bottom of Engine Compartment geonissan GA16DE 1.6L Engine 9 Nov 18th, 2003 01:02 PM
Funny engine sound SkylineGTR B13 91-94 chassis 5 Sep 13th, 2002 01:19 PM
