Old Jan 22nd, 2008, 08:51 PM   #1 (permalink)
dirtyhands0321
'89 Max wipers not working.
Hey fellas new to the forum. I just bought an old '89 Maxima that has been sitting for almost two years, and have been slowly pecking at bits and peices. Anyways, I have power at fuse box, fuse not blown, than no power to relay under the hood for the wipers. I'm guessing its either the switch or broken wire, might be the ladder since I the previous owner(not releasing his country of origin) decided it was cool to slice into a wire harness for the hell of it! Well just wondering if anyone has a wire diagram for the wipers or could point me into the proper direction. All in all, the car is great except when it rains and you can't see s$%1! Also I noticed that the washer fluid pump does not work as well, isn't there like a timing unit that controls a bunch of stuff including the wipers? Thanks guys, be easy on me, I'm a Nissan Virgin!
dirtyhands0321 is offline   Reply With Quote
Old Jan 24th, 2008, 10:02 AM   #2 (permalink)
internetautomart
it's Purple!!!
internetautomart's Avatar
get a test light and check for power coming from the switch when you put it on high at the switch's CONNECTOR. if there is no power there, then you need to check for power going into the switch.
Have fun!
Yes, I sell Replacement parts.
Yes, I have a website
Yes, you can PM/email me for more information.
Old Jan 26th, 2008, 04:12 PM   #3 (permalink)
dirtyhands0321
I found out what the problem was: There was a piggy back connector for an aftermarket sunroof, it was piggybacking off the wiper fuse which in turn spread the fuse connector which was not providing power to the motor! I found that out after I ripped relay boxes apart the steering console, the wiper motor, and a slew of other crap! Well now I'm off to rip apart the doors to fix some window motors, Thanks guys,
-----------Dirtyhands
Speedo is not working rorrobot B13 91-94 chassis 1 Sep 21st, 2007 02:23 AM
Wipers Wont Turn Off deanna_nass U13 1993-1997 Altima 2 Aug 26th, 2007 11:08 AM
Need help, speedometer still not working '91 max stans96max J30 1989-1994 Chassis 1 Aug 12th, 2006 03:49 AM
wiper not working on 96 Pathfinder... surfin Truck & SUV 3 Nov 1st, 2004 12:28 PM
Left Headlight lowbeam not working? UserA B14 95-99 chassis 3 Jul 25th, 2004 09:53 PM
