I would go with the same motor for the same reason. It's not swapping a like a B-series Honda engine.
Used VG30Es are cheap and plentiful. If the previous owner did good maintenance on it, these engines are pretty much bulletproof.
You can get some bolt-on parts that will yield a decent gain. Y-pipe and intake (JWT Pop-charger) will get you some power. Add a full-exhaust, advance the timing a few degrees and the car will be a strong runner.
Tom '92 GXE
