Old Dec 22nd, 2007, 03:10 AM   #1 (permalink)
chokko
engine swap
I have the v6 version of a 92 maxima and a standard tranny. What is the easiest swap to do? obviously the same engine will be but what other engines (that will make the car faster) could be swapped in?
chokko is offline   Reply With Quote
Old Dec 22nd, 2007, 08:20 PM   #2 (permalink)
internetautomart
I30t > Maxima SE
internetautomart's Avatar
the only swap is the same motor unless you want headaches out the wazoo
Yes, I sell Replacement parts.
Yes, I have a website
Yes, you can PM/email me for more information.
Old Jan 1st, 2008, 03:20 AM   #3 (permalink)
Tom 2000
I would go with the same motor for the same reason. It's not swapping a like a B-series Honda engine.
Used VG30Es are cheap and plentiful. If the previous owner did good maintenance on it, these engines are pretty much bulletproof.
You can get some bolt-on parts that will yield a decent gain. Y-pipe and intake (JWT Pop-charger) will get you some power. Add a full-exhaust, advance the timing a few degrees and the car will be a strong runner.
Tom '92 GXE
Tom 2000 is offline   Reply With Quote
Old Jan 1st, 2008, 09:15 AM   #4 (permalink)
internetautomart
I30t > Maxima SE
standard tranny =stick shift = VE30DE in 92
KA24DE engine swap into an 89-90 S13 rogoman S13 240SX 1989-1994 3 Jul 31st, 2008 12:22 PM
GT-R Engine details revealed ak47m203 2008+ Nissan GT-R 0 Sep 14th, 2007 12:12 PM
S13 Sr20DET Engine Swap 240drifter SR20DE/DET Engines 2 Nov 20th, 2005 07:42 PM
Engine Swap 2wd ~ 4wd 4x4munster Pathfinder 0 Sep 27th, 2005 01:27 PM
95 hardbody engine swap... eyeshyed Truck & SUV 5 Jul 6th, 2004 11:25 PM
