Links
Go Back   NissanForums.com > Nissan Models > Maxima > J30 1989-1994 Chassis
Old Dec 10th, 2007, 04:51 PM   #1 (permalink)
jej
89 keyless problem
Hey folks,I just bought a 89 GXE for my son for a christmas gift. I did'nt plan on it but I happend on to a great deal. My wife is a insurance agent and one of her policy holders is relocating to another state and told her that he needs to part with his maxima and that he would give it away to a good home. She told me that he bought the car new and that I might want to go take a look at it.We asked if we could stop by that afternoon. I could'nt belive my eyes it has 78000 miles on it and looks like it was taken off the showroom floor.Well due to the wifes company ethics she can not except gifts from policy holders so I gave him $500 for it. I left there thinking, feeling and knowing I just stoled a car. This man took the best care of this car, he only asked that I send him a photo next year of the car. NO PROBLEM. My issue is the keyless entry. He stated that he cant get it to operate. I went on line and was able to find the code number under the dash the number that follows the letter "S"and yes I hit the start/clear button first but to no avail, no beeps no nothing. Shoud'nt the keypad light up with the head lights on or when you press a button on the pad or open or close the door. I'm thinking there maybe a problem else where. Any help would sure be appreciated.
89 gxe mint
jej is offline   Reply With Quote
Old Dec 12th, 2007, 11:53 AM   #2 (permalink)
internetautomart
Flat 4, you know the Scor
internetautomart's Avatar
did you check the fuses?
if there is no beep, then you have a more serious problem. did you check both keypads?
Maxus 2008 will be in Chicago in June
All are welcome
Maxus is a gathering of Nissan Maxima enthusiasts from all over the continent.
Old Dec 12th, 2007, 01:03 PM   #3 (permalink)
jej
I did check both keypads. Is there a seperate fuse for the keyless entry. I do not have a shop manual yet. You dont happend to know which fuse do you. A new keyless control box is over 600 bucks. Do these keyless entry systems have a good life span. Thanks, Jim
89 gxe mint
Old Dec 15th, 2007, 07:26 PM   #4 (permalink)
internetautomart
they have a long life span, but the keypads don't.
I've never had a GXE, so I'm not sure which fuse it would be
All are welcome
Old Dec 15th, 2007, 10:32 PM   #5 (permalink)
thezman
could be a dead battery in the keyless entry remote not sending the signal to the car. try the panic button it is the least pressed so even if the other buttons are broken any light on the key fob should come on with that one.
the autozone near my house has a keyfob signal detector all it does is tell if your keyfob is putting out a signal or not I.E. dead battery.
thezman is offline   Reply With Quote
Old Dec 15th, 2007, 10:41 PM   #6 (permalink)
internetautomart
:rofl:
there is no fob, only a keypad on the door
All are welcome
Old Dec 15th, 2007, 10:50 PM   #7 (permalink)
thezman
Ah ok well there ya go haven't seen one without a fob in so long i forgot they used to do that keypad only thing lol.
Towing broke down cars since 1999. Including primary for local Nissan, chevy, kia, Honda, dealerships.
Old Jan 19th, 2008, 03:39 PM   #8 (permalink)
Jennerz_Dad
Here's what I did that worked for me: 1) found the three letter/number strings on the kepyad controller, and yes, used the "F#" string that started with "S". Press CLR then all the numbers following the "S" (ignoring any letters). Then the long constant beep started. During the long beep, entered the new code (4-7 digits or so) and nothing else, the long beep continued a short bit, then a few short beeps. Locked the doors and shut them. Waited a minute to give the system a chance to adjust to the new code, then pressed CLR followed by the new code. Worked like a charm. Good luck.
Jennerz_Dad is offline   Reply With Quote
Old Jan 19th, 2008, 04:18 PM   #9 (permalink)
jej
I think my problem is that I have no power to the module. I'm trying to locate the ignition-2 relay.The wiring schematic shows the relay but my repair manual does not show the location of the relay. And after the relay there is a circuit breaker.
89 gxe mint
Old Jan 20th, 2008, 09:23 AM   #10 (permalink)
internetautomart
are you using the FSM or a haynes/chilton manual?
All are welcome
Old Jan 20th, 2008, 12:02 PM   #11 (permalink)
jej
I have a chilton now and a FSM on the way. I have a feeling the relay I'm looking for might be one of the few just to the right of the fuse panel, the ones you can get at after removing a little trim. I was hopeing that a few folks would put me dead on the fix with this issue but maybe this is a not too common of a problem. But fix it I will and then this will be one of the best kept 1989 maxima a person could find and to think that I had stole it for $ 500.00.
89 gxe mint
Old Apr 16th, 2008, 09:14 AM   #12 (permalink)
WDRAPER
Same problem with 1991 Maxima
I have the same problem with my 1991 Maxima. Did you find the electical source? If so where is it?
WDRAPER is offline   Reply With Quote
Solution for P0500 VSS speed sensor problem on Nissan Sentra 96 wavepacket B14 95-99 chassis 1 Feb 7th, 2008 12:56 PM
2003 Xterra keyless entry problem UnstrungHarp General Discussion 0 Oct 25th, 2007 12:45 PM
Intermittent (no) starting problem Actionclaw S13 240SX 1989-1994 14 Feb 9th, 2006 08:33 AM
Sentra vibrations and other problem premk71 B15 2000-2006 8 May 13th, 2005 07:09 AM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 08:18 AM
