Old Nov 9th, 2007, 07:01 PM   #1 (permalink)
Chasity
Random starting problem..
I recently purchased an 89 Maxima. The car was running bad and had some trouble starting so I had a tune up done and the fuel filter was replaced. The "skipping" stopped, it cranked right up, and I had no trouble for about 2 weeks. Now I have two problems that may be the same one I suppose. First off, it doesn't want to start. It will turn over but won't catch. I've had a starter go out on a previous car and it isn't the same. The battery and alternator are good. This problem doesn't happen all the time, but is getting more frequent. Sometimes if I give it gas it will catch and sometimes not. Because of this I think it has something to do with the fueling system. The second problem is that when it is cold outside sometimes the car wants to cut off when stopping and has a rough idle if it doesn't cut off completely. This only happens when it is cold. I'm not a mechanic so I don't really know anything about cars so any help would be appreciated.
Chasity is offline   Reply With Quote
Old Feb 25th, 2008, 03:06 PM   #2 (permalink)
tex_rngr
starting problems
Hey there,
i have a '93 and it also has a weird starting issue. For mine, I have to turn the key to the "on" position then "Bump" the key forward. The starter makes a scratching sound but i can then turn the key normally and it starts right up. I have never asked what that was 'cause it always seems to work. i wonder if you are having the same problem.
tex_rngr is offline   Reply With Quote
Old Feb 25th, 2008, 03:45 PM   #3 (permalink)
internetautomart
I30t > Maxima SE
internetautomart's Avatar
nope.
never
Yes, I sell Replacement parts.
Yes, I have a website
Yes, you can PM/email me for more information.
Starting problem with AC on; AC cuts out. fleck B13 91-94 chassis 3 Aug 27th, 2007 01:52 AM
Strange but consistent starting problem penguin1944 U13 1993-1997 Altima 1 May 30th, 2007 05:33 AM
1993 maxima starting problem rbalan J30 1989-1994 Chassis 2 Jun 9th, 2005 05:53 PM
Freeze Starting Problem with GA16DE 1.6 georgyop GA16DE 1.6L Engine 8 Jan 11th, 2005 07:58 PM
95 Sentra starting problem. davmil GA16DE 1.6L Engine 6 Feb 12th, 2004 05:30 PM
