Old Aug 10th, 2006, 07:05 PM   #1 (permalink)
chiri
Question 91 Nissan Max SE Hesitation problems...help!
I have a 91 Nissan Maxima SE, automatic. It misses and stutters off of idle... but when taking off it then runs perfect, once you get a lil speed. I've ran fuel injector cleaner thru the car three times every time I went to fill up, and replaced the spark plugs and wires. There was a lil oil on the outside of 2 old plugs but none in the interior of it. The car still stutters when I tested it out after changing the plugs/wires, reversing from my spot in the driveway and giving it a little bit of gas to pull forward again. Sometimes the problem goes away but for the most part it is there. Any suggestions? Links to pics etc would help alot also. Thanks.
chiri is offline   Reply With Quote
Old Aug 11th, 2006, 09:17 AM   #2 (permalink)
CBPMIKE
Check the Oxygen sensor - disconnect it from the harness and see if it runs better to determine if this is a problem
CBPMIKE is offline   Reply With Quote
Old Aug 16th, 2006, 12:10 PM   #3 (permalink)
blackonblack
Change the MAF... That's my panacea for all 89 - 94 Maxima rough idle/shut off problems.
blackonblack is offline   Reply With Quote
Old Aug 17th, 2006, 02:49 PM   #4 (permalink)
internetautomart
it's Purple!!!
internetautomart's Avatar
Hardly.
WAY more injectors fail than MAFs
his symptoms are those of a bad injector or 2 or 3.
Yes, I sell Replacement parts.
Yes, I have a website
Yes, you can PM/email me for more information.
Old Aug 20th, 2006, 09:14 PM   #5 (permalink)
blackonblack
I remember doing all that stuff... Starting with the cheapest solution (oil change, air filter, spark plugs,) to some of the most tedious and time consuming (alternator, distributor & rotor cap, to belts). And it all was solved with a simple $40 MAF off a junk yard.
The fuel injectors and the plugs did have significant amounts of motor oil around their ring. But that is only normal for third gens in need of replacing the overall "engine gasket" (sorry I don't know the name of the red area where motor oil is added). That's the reason for most oil leaks for 3rd gen. Believe it or not, it takes a whole lot for motor oil to leak into a spark plug or an injector. Is not impossible, but it is very dificult.
Old Aug 20th, 2006, 10:24 PM   #6 (permalink)
alexnds
alexnds's Avatar
car stutters
It hard to say exactly what the problem is, but your problem is idle related sounds like. Could be any number of possible things, so these are suggestions only. Check for vaccuum leaks. Check for a bad MAP sensor (Manifold Absolute Pressure Sensor), or Idle Air control motor. The best thing to do is take it to a shop and have them put in a computer and see if it shows any codes. That way, you have some sense of what it might be. My suggestion is to clean throttle body first. Check for vacuum leaks. If you rule all this out, it might be bad injectors, as others have suggested. Try it in logical step by step fashion.
Here are some helpful links that I researched, that you may find useful to your situation:
http://forums. ******** .com/zerothread?id=126534
Engine Codes from 3rd Gen ECU
motorvate.ca v2.0 - *THE* DIY Maxima Website
How to Clean Throttle Body, Part1:
How to Clean Throttle Body, Part2
http://www.autozone.com/servlet/UiB...23d801f5181.jsp
How to Change Fuel Pressure Regulator
Buy some used injectors and have them cleaned/rebuilt:
Fuel Injector Cleaning and Flow Testing
or:
Accurate Injector Service - Fuel Injector Cleaning - Fuel Injector Balancing
How to Remove Fuel Injectors
http://www.autozone.com/servlet/UiB...23d801f5140.jsp
>How to replace your injectors
AUTOS & BOATS : Fuel Systems : Fuel System Service and Fuel-Injector Replacement : DIY Network
Let us know how it turns out
My web link
http://www.cardomain.com/ride/2140187
alexnds is offline   Reply With Quote
Old Aug 23rd, 2006, 07:38 PM   #7 (permalink)
richieb
Send a message via MSN to richieb
Well, having toyed with the idea of it "Not being Injectors"(or denying it on lots of work basis!!), I succumbed to the Idea, and $150(for 6) later, all slight misfires/stumbling, odd irratic idling... IT NOW is ok. I reakon, for my 2 cents, first, check injectors, and cleanig dont really help that much.
Check resistances of them, check continuity back to ECCS as well. I think, knowing my Max, I'd go there, age does eventually get them Injectors. and yours is the same age!!
I know there are many reasons, but I wieghed up age etc here, and experience too!
P>S> Anyone know why they are permanently connected to positive, or can I connect them to other side of the ECCS relay, and take power off them when car is out of use, cos it might well be the cause of the "Green" connector disease... moisture etc!!
richieb is offline   Reply With Quote
Old Aug 24th, 2006, 09:06 AM   #8 (permalink)
internetautomart
it's Purple!!!
it's electrically safer to switch the ground than the positive with an ECU. ALL manufacturers do it that way
Old Aug 25th, 2006, 02:52 AM   #9 (permalink)
richieb
Ah, ok, I looked at the wire map, and wondered.
Good Enuff.
Thanks.
Old Sep 7th, 2006, 09:57 AM   #10 (permalink)
chiri
Thank you for all of your suggestions. I am going to start trying to figure out what the heck will fix the probs.
Old Sep 28th, 2006, 08:49 PM   #11 (permalink)
jonesalexr
Send a message via AIM to jonesalexr
My car idles like shit and ive checked all of the above. It also accelererated like shit too until yesterday when i changed the fuel filter. I think it might be one, two, or three of the injectors. Ill have to check. but as far as the peppyness, change your fuel filter. My car is pretty quick now.
jonesalexr is offline   Reply With Quote
Old Oct 26th, 2006, 10:46 PM   #12 (permalink)
PeaceWarrior
Hey all, ive been having the same problem, and Im curious - Whats an MAF? I have a book but it doesnt mention MAFs
PeaceWarrior is offline   Reply With Quote
Old Oct 29th, 2006, 04:43 AM   #13 (permalink)
Edog1382
Send a message via AIM to Edog1382 Send a message via MSN to Edog1382
MAF is a Mass Air Flow sensor. On my 97 altima its a small sensor that attaches to the air filter housing. After replacing the stock intake with a aftermarket cone, my MAF just hangs there... up until today it ran fine (6 months with it) But today... my car started running like shit. Keeps stalling. Thats why I ended up on this page tonight. Im trying to find out why my car keeps on stalling. I know i need a new cat and o2 sensor. So I'll start by replacing that.
Edog1382 is offline   Reply With Quote
Old Oct 29th, 2006, 07:34 AM   #14 (permalink)
internetautomart
it's Purple!!!
Then you need a better book.
the maf is attached to the air filter box.
if you unplug it and the car runs fine to 2k then it may be your problem (car won't go past ~2k)
Old Oct 29th, 2006, 11:33 AM   #15 (permalink)
Edog1382
oh shit... i was thinking of the tempature sensor... Sorry... It was a late night!
Nissan Engines alexnds J30 1989-1994 Chassis 5 Jan 6th, 2007 08:12 PM
Brake Judder Info Slurppie Titan & Armada 25 Jan 3rd, 2007 10:05 AM
02 nissan spec problems jtrain Audio 0 May 17th, 2006 10:05 PM
Surges & hesitation - '95 Max doughboy1 A32 1995-1999 Chassis 1 Dec 20th, 2005 04:02 PM
Just bought a 1986 Nissan 300zx Non-Turbo - MANY problems - help!!! BoBakTXL Z31 300ZX(T) 10 Sep 16th, 2004 06:17 PM
