Old Aug 8th, 2006, 12:45 PM   #1 (permalink)
stans96max
Need help, speedometer still not working '91 max
Hey guys I'm still having a problem with my speedometer not working on my 91 maxima. Here is an update on what I have done thus far.
1. Speedo stopped working and I got a code 14 on ECU. I replaced the VSS and that didn't solve the problem. I reset the computer (both ways, by turning the screw on the ECU and by disconnecting the battery for 1 hour). But the code 14 returns.
2. Thought it might be a bad instrument panel, I replaced the panel and the speedo still doesn't work.
3. Thought I might have gotten a bad VSS from the parts store, I checked the VSS and it is good (showing 0.5V AC when rotated).
4. Thought it might be the VSS wiring. It showed good all the way to the firewall (couldn't see the wire any more so I stopped there).
5. Thought I must have a bad ECU. I replaced the ECU, but still the speedo does not work!! But the check engine light has not come back on.
I am stumped, I thought for sure it was the ECU. Do you guys have anything else I could try. Do you think it might be in the wiring some where? Some one please help.
Thanks
stans96max is offline   Reply With Quote
Old Aug 12th, 2006, 03:49 AM   #2 (permalink)
elusivemax93
if ur speedometer isnt working bro id advise to go under ur hood and check ur speed senor on ur tranny its usually i beleave towards the rar of the tranny on top its a two wire senor i beleave as once i forgot to reattach mine and went back in and saw we didnt attach it but ur senor might of went out so check the peed senor
elusivemax93 is offline   Reply With Quote
Fuel Injection Problem Max 94 JamesNguyen J30 1989-1994 Chassis 22 Aug 23rd, 2006 07:48 PM
speedometer / tachometer not working. Down shifting on expressway formasfunction U13 1993-1997 Altima 0 Apr 27th, 2005 07:55 AM
speedometer and temp gauge not working dbuck Truck & SUV 1 Sep 1st, 2004 11:23 AM
2003 Altima SE Speedometer Conversion ajusted L31 2002 - 2006 2 Jul 11th, 2004 02:32 AM
Help! What's the ECC Light All About? SentraGirl E/CA-Series & GA16i Engines 13 May 7th, 2004 12:03 AM
