Old Jul 12th, 2006, 08:55 PM   #1 (permalink)
stans96max
Speedometer doesn't work on 91 maxima. HELP!
Let me fill you in on what I have done....
The speedometer stopped working on my car and the check engine light came on. I read the codes and got a 14 which is the vehicle speed sensor. I replaced the speed sensor and reset the computer. This did not fix the problem and the check engine light came back on and is still giving a code 14. I thought it might be a wiring issue so I traced the wiring back as far as possible in the engine compartment and it is good. I don't know what to do next. Any suggestions?? Thanks.
stans96max is offline   Reply With Quote
Old Jul 13th, 2006, 07:07 AM   #2 (permalink)
MyGreenMax94
Think before posting
MyGreenMax94's Avatar
It might be a bad instrument cluster...
How did you "reset" your computer?
MyGreenMax94 is offline   Reply With Quote
Old Jul 13th, 2006, 11:34 AM   #3 (permalink)
stans96max
I reset the computer by turning the screw on the computer counter clockwise all the way and waiting until the lights blinked 4 times and then turning the screw back clockwise.
Is it a common thing for the cluster to go bad? My tach still works as well as my cruise control. But the speedo and mileage doesn't. Would the cluster going bad cause a vehicle speed sensor code? Thanks for the help!
Old Jul 14th, 2006, 07:18 AM   #4 (permalink)
MyGreenMax94
Try resetting the ecu by removing the negative cable from the battery for about 15 minutes...
Old Jul 16th, 2006, 11:07 PM   #5 (permalink)
internetautomart
it's Purple!!!
internetautomart's Avatar
there has been a case where the cluster was bad and it was killing the VSS every time it was being replced.
Yes, I sell Replacement parts.
Yes, I have a website
Yes, you can PM/email me for more information.
Old Jul 18th, 2006, 09:46 AM   #6 (permalink)
stans96max
Is there a way to check the VSS? Can you check it using a voltmeter or measuring resistance?
Old Jul 18th, 2006, 06:25 PM   #7 (permalink)
MyGreenMax94
Old Jul 19th, 2006, 10:27 AM   #8 (permalink)
stans96max
Thanks. I'll test my VSS this afternoon. I replaced the insturment cluster and the new one is doing the same thing. I took my battery cable off for about 1 hour. After driving for 5 minutes with the new cluster, the check engine light came back on. My new VSS may be bad or could have been blown by a bad cluster. I hope this is the case because I really don't know what else could be wrong. I'll keep you posted.
Maxima stupid speedometer sladeaudio A32 1995-1999 Chassis 1 May 30th, 2005 07:45 PM
87 Maxima cruise control doesn't work and engine quits when cold al.taylor General Maxima Discussion 4 Apr 29th, 2005 12:03 PM
Need '89 Maxima gear ratios Alan284 J30 1989-1994 Chassis 1 Feb 5th, 2005 09:26 PM
Automatic Maxima 96, speedometer error chishifu A32 1995-1999 Chassis 1 Oct 26th, 2004 06:27 PM
4th Gen Maxima FAQ/Help Guide Jeff A32 1995-1999 Chassis 1 Sep 13th, 2004 09:18 AM
