Old Jan 4th, 2006, 10:53 PM   #1 (permalink)
alexnds
alexnds's Avatar
how to clean out sludge in an engine?
Hi Gents,
I keep hearing about the stuff called "seafoam". Exactly what is this stuff and how does it work? Is it some sort of super cleaning agent? I have never seen this stuff in Pepboys or Autozone, so exactly where are you supposed to buy it? Also, if you buy you it, how do you use it? by adding it to your engine oil? By pouring it into your fuel tank as an additive to clean fuel lines?
If this stuff is useful in cleaning out gunk in a motor, does it do any harm to an older engine, such as mine with 146k miles, where tolerances/rings and so forth and no longer like new?
Any info highly appreciated.
My web link
http://www.cardomain.com/ride/2140187
alexnds is offline   Reply With Quote
Old Jan 5th, 2006, 05:39 AM   #2 (permalink)
nismosleeper
Send a message via AIM to nismosleeper
I got mine at O'reilly's, but I'm sure other places have it; ask them. The directions are on the can and I have heard that it really works. Good luck
Originally Posted by JDM240Turbo
Where is the oil filter? Gonna change my oil soon
nismosleeper is offline   Reply With Quote
Old Jan 11th, 2006, 02:02 PM   #3 (permalink)
92GOLDGXE
seafoam works wonders
92GOLDGXE is offline   Reply With Quote
Old Jan 11th, 2006, 02:03 PM   #4 (permalink)
92GOLDGXE
Wink seafoam
Old Jan 11th, 2006, 08:57 PM   #5 (permalink)
alexnds
alexnds's Avatar
how do I use the stuff?
I found this site that sells the stuff:
http://www.seafoamsales.com/
I have read that you need to find a source of vaccuum in your engine and introduce into the motor very, very slow via that hose, and the engine will want to bog down and die, but you must keep working the throttle to keep the engine from completely bogging down and turning off. You then leave it alone for about 15min, and restart the car normally after that, and that a huge cloud of black smoke, or carbon build-up will come of the tailpipe. I then heard, you put the remaining 1/3rd of the can in the fuel system, and the other remaining 1/3rd of the can into where your oil dipstick goes into, via a funnel, so it can mix with the oil and lubricate the lower part of the motor, and the stuff coming from the fuel system will lubricate the upper part of the motor.
Is what I describe a correct summary? If it is, where is a source of vaccum that I can introduce it, the brake vaccuum line? Can it be introduced into the motor by taking out the PCV valve temporarily and using that hole as the entry point? In other words, how do you do it exactly?
My web link
Old Jan 11th, 2006, 10:42 PM   #6 (permalink)
Bror Jace
Nissan Addict
Bror Jace's Avatar
Lightbulb
Seafoam is mostly overated:
http://theoildrop.server101.com/ubb/...c;f=5;t=004131
--- Bror Jace
Bror Jace is offline   Reply With Quote
Old Jan 12th, 2006, 07:45 AM   #7 (permalink)
alexnds
alexnds's Avatar
Seafoam and Other solvents
Originally Posted by Bror Jace
Thanks for your reply. I read almost the entire blog and it had more to do it seemed like, about people trading insults than doing any good automotive knowledge sharing. I like the fact that we have a nice crowd on this forumn.
I too have read about a product called "Auto-Rx" and "Seafoam". I have likewise read that seafoam has been around since WW-II and has been used to clean out Jeeps that were driven in harsh conditions. My feeling is that something has been around since WW-II still wouldn't be on the market if it wasn't working, although I myself have never tried it.
Here's my issue that I'm trying to resolve and I hope I can get good input on this. I bought a used 1993 Maxima that I feel was not well maintained by previous owner(s). After doing tuneup, changing PCV valve as well and so forth, the issue was not really resolved and would be worse when the motor was cold. It would get better as the car was driven. My feeling on this, is that the headgasket material would warm up further and seal better, under heat (from driving). In addition, I took the car to a shop and it was diagnosed with two bad injectors. I'm having work done this week to resolve that,replace all 6, and in addition, they'll use carb-cleaner to clean out my EGR valve.
I don't yet know what the car will run like with that work done, but I was hoping to clean out sludge from the motor to further extend its useful lifespan. I think part of the problem was the gas filter wasn't changed often enough, by the previous owner, no spark plug changes, wheel alignment was way off, tires were nearly bald, in other words, plenty of indication of a car that was pretty neglected. So, I already put so much money into this car, I can't do anything except hope it lasts another 2 years. So I'm hoping to clean out sludge and varnish in an effort to make the best of the situation.
Any advice really appreciated.
My web link
Old Jan 12th, 2006, 01:42 PM   #8 (permalink)
nismosleeper
"mostly overated"....why not just overated?...that's because it does help in some aspects. It is used by some mechanic shops, and the thread that you pointed out does not have much validity. It's cheap and worth a try.
Old Jan 12th, 2006, 06:18 PM   #9 (permalink)
alexnds
alexnds's Avatar
AutoRX or Seafoam which one to use?
Hi Gents,
Ok, so I have read the relative merits of both in great detail on many blogs. The question goes back to, what do I need to do given my automative situation of a car that was neglected? Will these things help? Which one will help more? Which one should I use if I just got replaced fuel injectors?
My web link
Old Jan 12th, 2006, 10:07 PM   #10 (permalink)
Bror Jace
Nissan Addict
Bror Jace's Avatar
Arrow
Guys, as nismosleeper was able to discern, I carefully said 'mostly' over-rated because the product does work, However, there's always a chance with a solvent-based cleaner like Seafoam that it can cause wear if used in too high a concentration or left in a sump for too long.
There's also a chance too much old sludge can be dislodged at once clogging filters and tight passages and doing damage that way.
As that BITOG thread pointed out, Seafoam is over-priced for what's in it (ingredients).
If you want to clean sludge out of your motor, Auto-RX (an ester-based cleaner) is probably the champ. The esters won't harm the innards of your motor like a solvent sometimes can.
Another approach to take is to do a couple short-duration oil changes using a gas/diesel 15W-40 motor oil. Even Supertech (Walmart) 15W-40 is worth using for 1,000 miles or so. These gas/diesel (HDMO) oils contain strong, strong detergent pacikages that will (safely) clean up neglected motors. Not sure how long it will take, however.
If you change your oil using one of these and the oil turns black quickly, it's doing its job ...
... safely.
--- Bror Jace
Old Jan 27th, 2006, 08:27 PM   #11 (permalink)
alexnds
alexnds's Avatar
cleaning it out
Originally Posted by Daryl Baines
I agree with Bror Jace it liquefies your sludge while you drive good luck.
Hi Guys,
Thanks for all the advice.
My web link
Old Jan 28th, 2006, 09:41 PM   #12 (permalink)
internetautomart
it's Purple!!!
internetautomart's Avatar
Originally Posted by alexnds
Hi Gents,
At a REAL parts store
Yes, I sell Replacement parts.
Yes, I have a website
Yes, you can PM/email me for more information.
Old Feb 4th, 2006, 10:31 AM   #13 (permalink)
93greysleeper
93greysleeper's Avatar
seafoam good stuff
I judged Seafoam according to consensus from a variety of personal experiences from others in forums and reviews, and also from the owner of a local marina. My best friend used it in his boat's inboard engine. You have to follow the instructions carefully in order for it to do what it's intended for. (i.e. running engine at higher rpm's while the stuff runs through, etc.) It worked successfully as far as we were concerned. It pushed out a lot of moisture, and seemed to keep it out for the whole season.
93greysleeper is offline   Reply With Quote
Old Oct 7th, 2006, 05:01 AM   #14 (permalink)
94MaxGXE
Send a message via AIM to 94MaxGXE
Where is the PCV valve located?
94MaxGXE is offline   Reply With Quote
Old Oct 7th, 2006, 02:04 PM   #15 (permalink)
Matt93SE
Will work for beer
Look in your service manual.
My website.
!!! KA24DET vs. SR20DET !!! MontyCrabApple SR20DE/DET Engines 242 Sep 6th, 2006 07:38 PM
CLEAN ENGINE SHOTS!....kinda pete? Member Rides 7 Jul 19th, 2005 11:09 AM
'04 Xtera Engine Seized Alan DeForest Truck & SUV 12 Jul 10th, 2005 06:07 PM
HELP: how to clean an engine bay zyg0te General Discussion 15 Apr 9th, 2004 04:19 AM
What do you use to clean your engine? fastmode General Discussion 15 Feb 21st, 2004 05:12 PM
