Old Nov 11th, 2005, 01:21 AM   #1 (permalink)
phreesoal
Need Help Finding Maintenance Parts
I'm looking at buying my own parts to have my car maintained. I know some of the parts I need, but a couple of others I cannot seem to find.
I know nothing about brands as I'm not a mechanic, so I would be buying to have a mechanic install them. I'd like to order everything online if possible.
I have a 1993 Nissan Maxima GXE SOHC 6cyl. Here's what I need and the info I have thus far:
-Timing Belt: (I don't know if I need a SQUARE or ROUND belt and which brand is suggested?)
Continental Square or Round
Bando Square or Round
-Belt Tensioner: (Which brand is suggested?)
NSK (OEM)
GMB
Water Pump: (Which brand is suggested?)
Atsugi (OEM)
GMB
NPW
These are the parts I cannot find or don't know exactly what to look for:
-Motor Mounts
-Shifter Bushings
(These I'm told I need to stop the hard shifting of gears when my car is cold and I immediately drive it. Initially thought I had a bad tranny but was told I do not.)
Thanks in advance for your help!
PS
phreesoal is offline   Reply With Quote
Old Nov 13th, 2005, 11:05 PM   #2 (permalink)
Matt93SE
Will work for beer
For parts that are critical to the life of the engine, I highyl recommend using OEM parts and only OEM parts for the belt, tensioner, and water pump. this is NOT a job you want to do twice (or an engine swap) because you wanted to cheap out and use a $29 water pump that leaked after a year and caused the timing belt to snap.
motor mounts... fill your stockers with urethane, or buy some OEM... also check ebay, as I've seen some out there for fairly cheap.
the shifter bushings are not your problem with an automatic. hard gear shifting is usually due to clogged/malfunctioning shift solenoids and valve body. remove, clean, replace, and see what happens. much cheaper than rebuilding the entire transmission, and much better than paying someone to flush it.
the shifter bushings for this thing are just a couple little plastic bushings on the ends of the steel cable where you move the lever on the tranny from park, neutral, etc. they sill affect how the car goes into gear when shifting out of park (if you have to pull it down into "2" before it will engage in drive), but it will not affect the actual harshness of the transmission shifting..
My website.
OEM Parts Suppliers... Matt93SE General Maxima Discussion 6 May 12th, 2008 09:35 AM
Non-Enthusiast needs help finding parts. ntropy General 240SX/Silvia/S12 200SX 1 Dec 7th, 2004 01:59 AM
Help finding GTI-R SR20DET Internal parts flameone SR20DE/DET Engines 2 Feb 19th, 2003 08:42 PM
help finding stock parts HKS20DET Off Topic 4 Jan 11th, 2003 08:16 PM
Finding Manufacture Parts!!! GOGO47 B14 95-99 chassis 8 Oct 24th, 2002 12:06 PM
