No Heat - 89 Max
I have a similar problem as one posted on 10/24/05. Heat & Air working fine until two days ago, when no heat surfaced. After reading posts in the other problem it sounds like heater core is clogged. The heater core was replaced about a year ago and I did a head gasket replacement 6 months ago so the coolant is clean. One of the hoses (upper) is warm to the touch up to the union on the firewall going into the core. Beyond the union it is cool. The bottom hose is cool. I am not sure how to flush the core. Do use garden hose or Compressed air?. Do you do one at a time with or without the engine running. Since the hose is hot up to the union point on the firewall, do you think that is where the obstruction is?
Any instructions would be appreciated - Thanks!
