Old Sep 13th, 2005, 01:12 PM   #1 (permalink)
rayroyw
91 SE Power Steering Hose
well, first post here guys. as usual i'm in mid-repair and
faced with a problem.
replacing high pressure power steering hose, and as per other posts, removed the four inch pipe on the bottom of
the pump. lo and behold, out popped a spring and what
the haynes manual refers to a spool. as you might guess,
it came out so fast, i'm not sure of the order to rebuild.
spring seems to seat well on the top of the union bolt, but
don't know which way the spool goes on -- one end is flat,
other has a machined tip. does the tip go into the sping
to seat into the end of the union bolt?
any quick help would be most appreciated. don't see any
blow-ups of steering pump around for guidance. got any
links?
DOUBLE R
rayroyw is offline   Reply With Quote
Old Sep 13th, 2005, 04:21 PM   #2 (permalink)
rayroyw
additional info
i see in another thread a reference to a flow control valve.
is that the correct name for the "spool"?
anyway, i may have answered my own question: i put the
spool in with the flat side down on the spring, pointed end
up into the pump (looked like there's a recessed area up
in the pump that the needle end would fit into, so what
the heck?). anyway, bled the system (i thought sufficiently) test drove and slowly but surely, the steering became stiffer and stiffer. so now i'm guessing i have to reverse the spool before i burn up the pump and the rack.
another question: with engine on, the p/s fluid in the reservoir should be flowing around visibly, right?
thanks for any and all responses.
DOUBLE R
Old Sep 13th, 2005, 05:27 PM   #3 (permalink)
Matt93SE
Will work for beer
I think you put the valve in backwards.
here's a shot from the FSM. hope that helps.
as for the fluid in the reservoir, yes it is supposed to flow through there. the hoses at the bottom are the return line from the rack, and the inlet line for the pump. it works as an accumulator/cooler/reservoir to have it like that.
My website.
Old Sep 14th, 2005, 05:38 AM   #4 (permalink)
rayroyw
thanks, matt93se! that's exactly what i was looking for,
and yeah, i put it in backwards. i'll post an update when
i've reworked it.
DOUBLE R
Old Sep 15th, 2005, 12:36 PM   #5 (permalink)
rayroyw
turns out i had the spring out of order too.
anyway, it's all straight. basically an easy fix, although working with tranny fluid is always kind of nasty, but i
know the system is thoroughly flushed with the two
drains.
easiest approach was to take the union bolt out with
the pipe. otherwise, there's no way to get a socket wrench
in there. just be sure to change all copper washers (you'll
probably only get four with the pressure hose and there's
two more for the union bolt into the pump on the pipe.
many thanks to Matt93SE for the help!
DOUBLE R
power steering. pete? B13 91-94 chassis 2 Apr 12th, 2005 04:08 PM
New Power Steering Pressure hose = more noise! FarAway B13 91-94 chassis 7 Mar 3rd, 2005 05:35 PM
Power Steering pressue hose removal kpa2 J30 1989-1994 Chassis 14 Feb 20th, 2005 10:01 AM
power steering pump pressure malaysia_boy B11/B12/KN13 82-90 chassis 9 Jan 31st, 2005 11:21 PM
Help with TT Power Steering Pump kevrock529 Z32 Chassis 300ZX 7 Jun 10th, 2004 04:54 PM
