Old Aug 6th, 2005, 06:21 PM   #1 (permalink)
maximus93
Need advice on the A/C system.
I got a 1993 Maxima GXE with the VG30E engine. The air conditioner was working fine blowing fairly cool air while driving then suddenly the cool air became warm air. At first I thought it may just need the freon recharged R134a but while looking under the hood I saw a fuse marked A/C next to the battery so I'm not sure if this could be the problem since the air turned warm so suddenly.
Does anyone know what this fuse is for...is it just for the blower motor?
I don't really want to spend $25 to replace it if it is not the problem.
Also what is the average cost to recharge the A/C?
I have gotten estimates from $50-$175.
Thanks.
maximus93 is offline   Reply With Quote
Old Aug 6th, 2005, 08:43 PM   #2 (permalink)
DonaldHays
Exclamation
My ac is doing the same just starts to blow warm at times, I turn it off for like 2 mints then back on and eveything else is fine. I havent had a chance to get it checked out yet tho
Donnie H.
DonaldHays is offline   Reply With Quote
Old Aug 8th, 2005, 01:05 AM   #3 (permalink)
gapboi210
More than likely what is happening is your low pressure switch is kicking in. If the system is low on freon it will disengage the compressor to keep from any damage occuring. Since you said the air was fairly cool that means you are low on freon and that is more than likely what is happening.
gapboi210 is offline   Reply With Quote
Old Aug 8th, 2005, 08:44 AM   #4 (permalink)
Matt93SE
Will work for beer
yup.. what he said.
for the cheap fix, you can go to any auto parts store and buy a simple recharge kit for about $10-15 and you can do it yourself... since you're just low on freon, I don't see any need to take it to a shop and have it worked on.
My website.
Old Aug 16th, 2005, 09:04 AM   #5 (permalink)
r1style
Send a message via AIM to r1style
I had a similar prob too. I took it to the shop and they filled my a/c with another bottle of freon.
UNFORTUNATELY it didn't solve my problem. The a/c will blow cool air when it's not TOO hot outside. Once it get's really hot the a/c will only be cool when I am driving. When I am idle at a red light the cool air will stop. This doesn't happen ALL the time. I'm not sure if the hot weather has an effect on it.
help??
r1style is offline   Reply With Quote
Old Aug 16th, 2005, 04:57 PM   #6 (permalink)
brianw
Nissan Addict
Send a message via ICQ to brianw Send a message via AIM to brianw
Check the fan?
Compressor going bad? If the AC compressor is going bad, you're in for an expensive repair...
brianw is offline   Reply With Quote
Old Aug 16th, 2005, 06:45 PM   #7 (permalink)
gapboi210
sounds like it could be your condenser is bad. If it is only cold when u are driving i.e on the highway then it might be that. I have seen some super cheap on eBay but form what I hear, you get what u pay for.
Old Aug 17th, 2005, 12:13 AM   #8 (permalink)
Matt93SE
Will work for beer
could be one of many things.. have an experienced A/C shop repair it. will save you many hassles and headaches in the long run over trying to do it yourself.
My website.
Old Sep 20th, 2006, 10:38 PM   #9 (permalink)
gabesn200sx
Send a message via AIM to gabesn200sx Send a message via Yahoo to gabesn200sx
My girlfriend has a similar problem. She has already replaced the compressor, checked all the lines and everything seems to check out fine. She still hasn't fixed the problem, but it seems like it has something to do with the temperature control. I think that maybe the flap that controls the cool air from the hot air may be malfunctioning. I'm still in the works of repairing it. The compressor runs as normal, but the air is only somewhat cool. Keep me posted and I'll see what I can dig up
Gabriel Soto
gabesn200sx@netscape.net
Del Rio, TX
gabesn200sx is offline   Reply With Quote
A/C problemwith NA 1995 richlo U13 1993-1997 Altima 1 Aug 5th, 2005 08:22 PM
A/C problems... ZSCORE B15 2000-2006 4 Jul 28th, 2005 01:44 AM
bad a/c system? kingsentra B14 95-99 chassis 18 May 27th, 2004 12:46 AM
a/c system 91SERHondaKiller B13 91-94 chassis 2 May 7th, 2004 07:24 AM
need some bolt sizes for my stromung and HS exhaust system... Naemus Naturally Aspirated 4 Mar 2nd, 2003 08:06 PM
