Go Back   NissanForums.com :: Nissan Forum > General > Car Clubs > Houston Nissan Enthusiasts
Old Jul 27th, 2004, 10:23 PM   #1 (permalink)
kwd2kSE
Nissan Fanatic
REAR Big Brake Kit on the Max
Yep, as the title says, Matt and I have finished the REAR BBK on my car. It is absolutely awesome. Here's the announcement over on the Org and my 200 mile review below the link.
http://forums.maxima.org/showthread.php?t=326162
__________________________________________________ _______________
OK. I'm the test mule for the Matt's front, and now the rear brake kits. I've got almost 200 miles on the rear brakes at this point, so its time for me to chime in with my observations.
After the pics above were taken and before we road tested the car, we powdercoated the rear rotors black to make them match the fronts. We made the mistake of getting some powder on the wear surface. This on top of the zinc plating was a mistake. It took about 100 miles to wear it off. Once it was gone, the pedal feel changed for the better. I also have stainless brakes lines front and rear now. As Matt mentioned, I have Valvoline synthetic brake fluid.
Compared to having the 300ZX front calipers and stock rears: brake pedal travel is about 1/2 cm more now before brake engagement-VERY minor. The pedal is firmer. The sponginess we encountered on the initial drive is gone - I believe when the powder coat and the zinc plating was off the pad surface this issue went away. I do not feel a master cylinder change is necessary. Under normal, average, conservative driving conditions (ie, not trying to throw passengers out the windshield) the brakes behave comparable to the stock system. When you push the pedal harder, you better be holding on. On a 50mph to zero demo for my 16 year old son today, his rear end came off the passenger seat and was held in by the seat belt. Thought his eyes were going to pop out. And yes I'm older, the stop made my nauseous again - it stops that hard and fast. The ABS engaged twice, only for a split second , on the stop. I'm also running Bridgestone S-03's with 1/4 tread, size 245/45/17. These tires stick like there's glue on the road.
Last but equally important for me. With the front 300ZX calipers and stock rears, the nose of the car would dive drastically on heavy braking. Now, the car stays fairly flat, similar to the stock brake system. The brake bias seems to be just a tad more to the back compared to stock. But thats my 30 years of agressive and racing driving experience saying that, not any sophisticated equipment. All you guys with front only BBK - 300ZX, Brembo, Wilwood AP Racing, etc - this rear system is a must. And for you guys running cheap tires, get some good tires to get the full potential out of these brakes.
Mike
Handling/Performance-VOLK LE37T-18x8.5,255/40/18. Addco RSB,Stillen FSTB,Eibach ProKit,KYB GR2,Cattman Y & B pipes,GAB,BlehmCo custom front & rear Big Brake Kits
Appearance-3M clear mask, clear side markers, AE door sills, engine cover, headlights & pedals.Lots of Zaino.
Audio-Two JL Audio 10" subs in a custom box w/JBL 300 watt amp,Polk EX3500 tweeters,Sirius sattelite.
kwd2kSE is offline   Reply With Quote
Old Jul 28th, 2004, 08:08 AM   #2 (permalink)
d_warner
Official HNE PIMP
d_warner's Avatar
Location: Huntsville / Houston Penis: Larger than yours is! Job: Pimp
Send a message via ICQ to d_warner Send a message via AIM to d_warner Send a message via Yahoo to d_warner
Wow. As soon as Matt lets me know how much, I'll be robbing a bank!
Don't Piss me Off!
d_warner is offline   Reply With Quote
Old Jul 28th, 2004, 09:19 AM   #3 (permalink)
Matt93SE
Will work for beer
I need a 4th gen guinea pig too..... if it fits, I'll install it for free.
My website.
Old Jul 28th, 2004, 09:50 AM   #4 (permalink)
HNE
Evil Moderator
HNE's Avatar
Send a message via ICQ to HNE Send a message via AIM to HNE Send a message via MSN to HNE Send a message via Yahoo to HNE
Do you have a payment plan?
d_warner@Yahoo.com
HNE is offline   Reply With Quote
Old Jul 28th, 2004, 10:55 AM   #5 (permalink)
Matt93SE
Will work for beer
LOL!
Sure... you pay, I install.
BTW, I forgot to return your tripod... you got any progress on those videos?
My website.
Old Jul 28th, 2004, 01:24 PM   #6 (permalink)
Flying Vv
Mofo fo life
Flying Vv's Avatar
Send a message via AIM to Flying Vv
what about a B15 guinea pig? i'd be down
Originally Posted by muchachomaloo
Ok... maybe I am just retarded then :(.
^^ The truth finally comes out.
Flying Vv is offline   Reply With Quote
Old Jul 28th, 2004, 01:48 PM   #7 (permalink)
Matt93SE
Will work for beer
prolly not.. not unless you have some HUGE front brakes already..
plus I'm not going to do all this work for another car. if it doesn't fit, then it doesn't fit.
My website.
Old Jul 28th, 2004, 02:27 PM   #8 (permalink)
elusivemax91
elusivemax91's Avatar
Send a message via AIM to elusivemax91 Send a message via Yahoo to elusivemax91
Talking 3 gen big brake conversoin
hey matt what about a 91 Maxima se big brake conversoin?
elusivemax91 is offline   Reply With Quote
Old Jul 28th, 2004, 03:56 PM   #9 (permalink)
Matt93SE
Will work for beer
Do you have a front brake kit yet? there is absolutely no reason to touch the rears until you have the fronts done. In fact, it's dangerous to run with too much rear bias.
But if you really want big rear brakes, use Z31 rotors in the back and keep your stock calipers.. The Z31 rotors are about an inch larger than factory, and all you need is a bracket off an 89 or early 90 model SE Maxima. I did this conversion years ago, and it's enough for me, even on heavy track use.
http://mattblehm.com/pics/car/brakes/ scroll down to the bottom and look at the rear*.jpg pics.
If you cant find them, go to forums.maxima.org and get in touch with Jeff92SE and he'll hook you up with a set.
My website.
Old Jul 31st, 2004, 12:09 AM   #10 (permalink)
mclee45
mclee45's Avatar
Send a message via AIM to mclee45
matt, will you be making a rear relocation kit for 5th gens? Kind of like your front relocation kit. I would probably be more interested in that one since this Z BBK would probably be out of my price range
mclee45 is offline   Reply With Quote
Old Jul 31st, 2004, 05:38 AM   #11 (permalink)
Matt93SE
Will work for beer
I thought about it, but there's no rotor out there currently that will work- I'd have to have them custom made, and as $200/ rotor for that, there's no real point in it. you'd spend almost as much on the relocation as on this kit.
the parking brake cables don't have enough slack in them, so they would have to be replaced/stretched to make it work as well as the rotor. not much fun there.
My website.
Old Aug 17th, 2005, 10:44 AM   #12 (permalink)
Jeff92se
It's a big pain to find these brackets in the bone yard. I have these brackets fabricated and IN STOCK. I just got another batch of 5 sets done. I don't get these made very often. $90 shipped. That's a good price considering how big these are and how much cutting there is to do. Plus you don't have to wasted a day digging around in a dirty boneyard.
Jeff92se is offline   Reply With Quote
New suspension Group bys ILP Performance Group Buys 4 Aug 31st, 2005 02:09 PM
Big Brake Kits johnsonsRIDE Suspension & Brakes 6 Jul 8th, 2004 03:18 PM
Altima Rear Brake Conversion Presea08 Suspension & Brakes 0 May 16th, 2004 02:14 AM
rear brake piston nnoriega B13 91-94 chassis 5 Apr 28th, 2004 06:12 PM
HP brake kit talk... nismo200 Suspension & Brakes 12 Oct 5th, 2002 09:03 PM
