that used to be your radiator support! and it is, was structural... I would try to replace that asap! (if its a daily driver) might check with aftermarket for a replacement (call a local body shop and ask who they use)
check the aftermarket for a radiator support, drill out the old welds, square up the front end and weld in the new supt or.... if you use a patch, weld instead of bolts, but square the frt end..
body shops have all the spec's, but I would go from a fixed point back by the hood hinge to the opposite side of the rad supt (criss cross) get the same measurement from both sides and its square..
if you want more of a bulge in the fender, get 4wd fenders, they mount up the same etc.. The (a/m fenders) fit & finish will not be the same, read all the small print etc Might check with a local body shop to see where they buy their a/m parts, then you can see before you buy...
This bumper was bolted on extremely tight. I had to go to Sears and get another 1/2 inch drive ratchet, and another 18mm socket. The first three bolts took a huge effort, the third one I cut away with a Dremel.
