» Site Navigation
» Featured Product
» Network Links
Feb 20th, 2013, 11:26 AM
#31 (permalink )
Ol' woody! Love it! What will you coat the wood with?
Feb 20th, 2013, 01:48 PM
#32 (permalink )
Nissan Fanatic
Coating with epoxy. Here are the frames, 2 in front of the wheel, and 4 in back.
Feb 20th, 2013, 01:51 PM
#33 (permalink )
Nissan Fanatic
Originally Posted by
SPEEDO
if you could find a bedside in a wrecking yard, that would be ideal
The whole bed needs to be replaced. I've been on the look-out.
Feb 20th, 2013, 02:40 PM
#34 (permalink )
Nissan Fanatic
Just ordered a patch panel from JCWhitney. This is an image of the drivers side, but I did order the passenger side panel.
Feb 21st, 2013, 11:45 AM
#35 (permalink )
Nissan Fanatic
This is the top section of weather strip on the windshield.
Is this easy to remove and replace?
I want to get under there to treat rust.
Feb 21st, 2013, 01:34 PM
#36 (permalink )
I Live Here
if I remember right, it lays under the glass, might ask a glass guy just to be sure..
Feb 21st, 2013, 03:19 PM
#37 (permalink )
Nissan Owner
SPEEDO
I don't think it does. At least not on my 94 ...mine is coming off by itself. It's just a push in type of molding as far as I can tell, but I'm not a glass guy exactly either.
-R
1994 D21 2.4, 2wd, 5spd XE
Feb 22nd, 2013, 08:23 AM
#38 (permalink )
I Live Here
if not, use a razor knife and cut it out, then silicone it back in... a thought anyway
Feb 23rd, 2013, 11:50 AM
#39 (permalink )
Nissan Fanatic
Good idea; probably will go that route.
Feb 25th, 2013, 08:35 AM
#40 (permalink )
Nissan Fanatic
This side is looking better.
Feb 25th, 2013, 08:47 AM
#41 (permalink )
Lookin good. How do you find the time to do all this work? I feel like my projects always get so drawn out because I'm so busy...
Feb 25th, 2013, 09:54 AM
#42 (permalink )
I Live Here
wow! your truck has the pop up tie downs! I havent seen those in years!
Feb 25th, 2013, 10:05 AM
#43 (permalink )
Nissan Fanatic
wilburk
It does take to much time. Every time I spend a couple hours doing the body work, I come into the house ready to write a check for a new one.
Feb 25th, 2013, 10:16 AM
#44 (permalink )
Nissan Fanatic
SPEEDO
I didn't know they were there until the other day when I pulled the topper (then pulled the bed-liner.)
Here are a couple pictures from this morning.
Feb 25th, 2013, 12:18 PM
#45 (permalink )
Nissan Owner
Wow, that's coming along nicely! Keep is in the loop.
-R
Linear Mode
