2400 motor swap help please - Nissan Forum
post #1 of 8 Old Nov 10th, 2009, 08:16 AM Thread Starter
I bought a 1994 Nissan 4x4 with a 2400 knowing that the motor had bottom end noise, However the head had been recently worked and it had new timing belt and oil pump. Well I took the motor out and it had a rod sticking out the side. I have found a 1995 with a 2400 in it. Now for my question: Are all 2400 short blocks the same. Can i take my head and intake off of my short block and put it on the 95 short block? Or can I put the whole long block in. Thanks in advance for your help
dagosrods is offline
post #2 of 8 Old Nov 10th, 2009, 09:55 AM
I Live Here
it should all swap out
SPEEDO is offline
post #3 of 8 Old Nov 10th, 2009, 04:55 PM
coyotekid's Avatar
will a 2400 eng from a 97 model work in a 93 i was told it wouldnt but they do look pretty similar can anyone tell me what all is diffrent both of these are 2wd vehicles with 5 spd
coyotekid is offline
post #4 of 8 Old Nov 11th, 2009, 09:48 AM
Hardbody Freak
zanegrey's Avatar
there are small differences..
the dizzy will have to be brought over along with the t-chain cover .
you will have to use the peripheals of the year u r swapping to..
zanegrey is offline
post #5 of 8 Old Nov 11th, 2009, 11:25 PM
coyotekid's Avatar
if i use my intake and fuel rail along with the timing cover and dizzy is there anything else i will need to change over for this to work i am trying to figure out my best way to do this
post #6 of 8 Old Nov 11th, 2009, 11:35 PM
Hardbody Freak
zanegrey's Avatar
as far as i can remember yes..
just remember that all the things from the 93 must stay with the 93 ..
also try a search .. i know some one else has done this swap recently..
zanegrey is offline
post #7 of 8 Old Nov 12th, 2009, 10:35 AM
2400
why do different part # come up when I want to order a master rebuild kit for a 1994? the kits come for 1990-1994 and 1995-1997
HELPME is offline
post #8 of 8 Old Nov 12th, 2009, 11:33 AM
Hardbody Freak
zanegrey's Avatar
the productions date may be the reason..
the pd are usually 11/95 that would be a 96 truck per the manufacture..
parts places just go by the year mostly..
also in transitional years the manufacturer will use up the parts it has on hand b 4 using the new model year parts..
my 95 is the same as 90 thru 94 its pd is 6 of 95 ..
96 and 97 are different
zanegrey is offline
  Nissan Forum > Truck & SUV > HB Truck
Gear in this thread - nissan Motor by PriceGrabber.com
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
