Isssues about Manual Transmission gear oil
Folks. I have a '97 4wd(LSD), manual 5spd, extended cab HB. Lately the transmission whines when I put it gear first thing in the morning which I believe is caused by low oil in the transmission. My issue is related to the GL designation of the gear oil. The owner's manual states that 80w-90 GL-4 should be used but I have not found GL-4 anywhere. The oils that I have found all are 80w-90 GL-5 (castrol, exxon, lucas).
Would I cause harm to my transmission if I change the transmission gear oil with 80W-90 GL-5?
Thanks in advance.
