D21 fuel and temp guage problem - Nissan Forum
post #1 of 2 Old Aug 4th, 2007, 03:46 PM Thread Starter
gvw
gvw's Avatar
I have a 1990 Nissan D21 and my fuel and temperature gauge just recently went out. I'm in the process of just trying to figure out what is wrong and it seems most consensus leads to the voltage regulator, (which controls these two gauges from the look in the schematic) being the problem.
I recently talked to my local Nissan dealer and they mentioned that it could be a part called the Unified Meter. Seems like most say it is the voltage regulator. At least the voltage regulator isn't to much, about $60 here locally, but I'm sure it will be a pain in the arse to get to behind the instrument cluster.
Any other advice from the Nissan experts around here.
Thanks,
Glen
gvw is offline
post #2 of 2 Old Aug 5th, 2007, 03:55 PM
NF Mod/Nissan Master Tech
smj999smj's Avatar
I don't recall seeing unified meters in Nissans until the very late 90's or early 2000's. Your HBody should have a I/P voltage regulator attached to the back of the instrument cluster that is most likely your problem. Nissan used two differant brands, so you may want to remove the cluster to identify the one you need. Either will work the gauges, but one make has shorter wires than the other so it's best to order the correct one. The cluster isn't too bad to remove. Remove the finisher around the cluster to access the four screws that hold the cluster assy. to the dash. Remove those screws, pull out slightly, unscrew the speedo cable from the back of the cluster, pull out far enough to unplug the harness and out she goes.
smj999smj is offline
  Nissan Forum > Truck & SUV > HB Truck
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Speedo / tach/ fuel / temp guages Heather Pathfinder 7 Oct 23rd, 2010 03:49 PM
Fuel Temp Sensor FYI MaxQ Z31 300ZX(T) 0 Jul 28th, 2005 06:23 PM
Fuel and Temp Guage? cncwhiz B11/B12/KN13 82-90 chassis 1 Apr 10th, 2005 01:10 PM
96 king cab fuel temp sensor location ? alan scott Truck & SUV 6 Aug 10th, 2004 10:34 AM
Is there any connection between temp gauge & fuel gauge? Dave_27 E/CA-Series & GA16i Engines 3 Jul 12th, 2004 04:59 PM
You may post new threads
You may post replies
BB code is On
