Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Truck & SUV > HB Truck
Old Sep 29th, 2006, 09:56 PM   #1 (permalink)
95truckin
PCV valve and valve cover gasket
I have a 1995 x-cab HB 2.4L 4x4 and was wondering where the PCV Valve is located? I have looked for hours and saw nothing.
Also, my truck cuts out slightly and has problems idling sometimes. I am going to change the fuel filter (it has been 2 years) and I noticed that the back side of the valve cover is leaking. Should I replace that gasket also? Could that be causing my idle problems? I just replaced this about a year ago. I followed the chiltons guide bolt pattern and torque specs. Why dose this leak now? It is a rubber gasket. Dose it need some liquid gasket? Any info would be great..
Thanks
Jason
95truckin is offline   Reply With Quote
Old Sep 29th, 2006, 11:39 PM   #2 (permalink)
88pathoffroad
Moderator
88pathoffroad's Avatar
Send a message via AIM to 88pathoffroad
The PCV valve should be on the other end of the PCV hose attached to the air box. It has a small white filter inside the airbox for the PCV system.
The valve cover screws come loose sometimes, have you re-torqued them? No, an oil leak won't cause idle problems.
Admin of NPORA, mod for Nissan-Infiniti Forums, NissanForums.com, NissanHelp.com, AllNissans.com and VGPowered Forums
'88 Pathfinder: 6" of lift, 33x13.50 Swamper LTB's, Rancho 9000's, L&P Stage 3 steering system, K&N, Pacesetter headers and 2.5" exhaust, Lock-Right locker, 110A alty and electric fan swap, dual batteries, 700W+ worth of PIAAs, etc.
Come play 4x4 Mayhem!! http://www.4X4mayhem.com/register.php?REF=176
88pathoffroad is offline   Reply With Quote
Old Sep 30th, 2006, 02:34 AM   #3 (permalink)
95truckin
I have the regular 2.4L not the z24. There is nothing once I pull off the hose. I heard it is somewhere else for my truck. Do you have a picture or a better description?
Old Sep 30th, 2006, 09:40 AM   #4 (permalink)
88pathoffroad
Moderator
Nope. I looked through the 95 FSM for that info...couldn't find any pics. The PCV should be somewhere either on the valve cover or nearby.
Old Sep 30th, 2006, 10:19 AM   #5 (permalink)
95truckin
That's where my other cars have neen in the valve cover. The book shows the PCV line comming out of the airbox and I follow it to the valve cover and take off the hose, NOTHING, just a hollow nipple that's pressed in. I'm starting to think there isn't one. I have had this part for two years and haven't been able to change it. I've been told: on the firewall side of the engine, in the valve cover, my chiltons guide says (who knows, but it isn't in their stupid drawing). Hell even the local dealership didn't know where it was, they said it was easy to find blah blah blah, but when I had them show me. Suddenly it is hard to find and they wern't able to find it. Damn Nissans!!!
Old Sep 30th, 2006, 04:47 PM   #6 (permalink)
Oldnissanguy
Nissan Addict
Oldnissanguy's Avatar
I can't tell you for sure on the 95, but I just changed the PCV valve on my 97 this morning. If you remove the oil filter you will see it forward of the oil filter mount. It screws into box like thing that's on the side of the block, threads forward and nipple pointing to the rear.
Oldnissanguy is offline   Reply With Quote
Old Oct 1st, 2006, 05:16 PM   #7 (permalink)
95truckin
Thanks! I just changed my oil yesterday. Do I have to drain the oil to remove the oil filter? I think it might be worth replacing the oil to get that thing in. The truck is approaching 100k so this should be changed, it's getting old. Thanks again!!
Jason
Old Oct 1st, 2006, 08:27 PM   #8 (permalink)
Oldnissanguy
Nissan Addict
I've never tried it but suspect you would loose no more than 1/2 to a quart of oil by just removing the filter. Maybe some of the wiser heads here know for sure.
Remember, your 95 may be different than my 97. They may have found some other place to hide the PCV valve so don't be totally crushed if it's not where I indicated. You will find a 19mm ratcheting box wrench very useful.
Old Oct 5th, 2006, 01:05 AM   #9 (permalink)
95truckin
GREAT idea!! I took the filter off and there it was. I had been lookin for this for 2.5 years now. Thanks again. I also managed to fix the spuratic ideling problem I have been having for the last 2.5 years..
Old May 6th, 2007, 10:59 PM   #10 (permalink)
Macneil
Good tips! My 93 has been idling at about 800 rpm but it jumps up and down on its own, I'll have a look at my PCV valve!
Macneil is offline   Reply With Quote
Valve cover gasket 96SentraGXE B14 95-99 chassis 0 May 30th, 2006 04:50 PM
Valve cover gasket pete2.0 GA16DE 1.6L Engine 13 Mar 2nd, 2006 04:48 AM
torque specifications for valve cover gasket Junk GA16DE 1.6L Engine 2 Mar 8th, 2005 03:31 PM
Valve cover gasket + spark plug seal ppupet L30 1998-2001 Altima 1 Jul 2nd, 2004 06:59 PM
valve cover gasket hector200sx GA16DE 1.6L Engine 3 Jun 1st, 2004 11:04 PM
