Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > General Z Discussion
General Z Discussion For General Z discussion
Old Jan 13th, 2004, 04:06 AM   #1 (permalink)
SalliC
Posts: n/a
Cutting Out Problem - Pls Help!
Hi - I'm new here so hope I'm posting in the right place. I am in UK, have Japanese import 300ZX Fairlady, 1991. I would be the first to admit I know nothing about cars, have just loved driving it for the last 6 years!
I suddenly have a cutting out problem that I am having trouble getting diagnosed and wonder if any of you have heard of before?
Engine starts normally, then after several minutes everything cuts out dead (happens whether driving or engine is just idling) - engine stalls and all ignition lights go off. Although I can turn the ignition back on immediately, the engine won't start again for maybe 20 - 40 mins, though the starter motor is turning and the battery is not flat. After that time, the car starts again fine, but then stalls again after a few mins. Does it every time.
Don't know if the following is relevant, but there is an alarm in the car which was working perfectly before the car first cut out. I have subsequently been told the alarm has had it and it has now been bypassed. There is also an immobiliser which I have had checked and been told it is working perfectly.
My mechanic has been looking at this for me for 2 days and has so far been unable to find a problem. Do you guys have any ideas please?? Have you heard of this happening before on Z's?
Old Jan 26th, 2004, 06:29 PM   #2 (permalink)
rizzspeed
Send a message via AIM to rizzspeed
Sounds like an intermittent electrical problem. Fuel Pump fuses, relays, and the pump itself should be checked. Throttle Position Sensors should also be checked and/or cleaned. Fuel lines along with the filter, pressure regulator and fuel dampner should be looked at.
rizzspeed is offline   Reply With Quote
Old Jan 26th, 2004, 06:47 PM   #3 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
Check your CAS connections it may be loose or need cleaning. Also do a ECU check as well.
Spongerider is offline   Reply With Quote
Old Feb 4th, 2004, 12:13 PM   #4 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
I would check the power transistor with your symptoms it definitely sounds like the problem. For more info check here:
http://www.aus300zxclub.com/tech/ptu.../pturepair.htm
Troy
SHIFT_Happiness
1992 S13 240SX SE Fastback KA24DE 5 spd - Type X Aero & Seibon Carbon Hood & Hatch -soon GT28RS
1993 U13 Altima SE KA24DET 5 spd w/ Nismo LSD - A high hp FWD can be fun (GT30R Turbo inside)
1990 Z32 300ZX VG30DETT 5 spd - 600HP & Very Civilized (working on twin GT28RS turbos)
Still trying to import a 1988 R31 Skyline GTS-R w/ RB20DET-R - only 800 produced (legal under show/display regs)
KA24Tech is offline   Reply With Quote
Old Sep 24th, 2006, 09:40 AM   #5 (permalink)
vuroomm
Send a message via Yahoo to vuroomm
did you find out what your cutting out problem was. I have the same problem. please help me. vuroomm@hotmail.com
vuroomm is offline   Reply With Quote
Shifting problem blazebridge U13 1993-1997 Altima 5 Jun 23rd, 2004 11:25 AM
problem with alpine amp, need help ahardb0dy Audio 6 Jan 1st, 2004 01:06 PM
Engine idle freaked out, went right back to normal sfhellwig GA16DE 1.6L Engine 27 Oct 24th, 2003 01:40 PM
97 Pickup EGR problem viper2 Truck & SUV 11 Aug 30th, 2003 06:27 AM
Hi all, I'm new here. Got a problem with my B14, pls help. Mayonaise B14 95-99 chassis 8 May 12th, 2003 06:03 AM
