Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > General Z Discussion
General Z Discussion For General Z discussion
Old Nov 29th, 2003, 03:47 AM   #1 (permalink)
87_300zxT
Electrical Problem Plz Hlp!
I have put in 2 new batteries, and also installed an alternator twice to make sure it was done right, then I got new post clamps, stripped the end of the batt wires and cleaned them, then installed the new clamps, I also cleaned the ground wire and put a new end on it and cleaned the body where it bolts to, everything else electrical is working correctly(when the battery is charged, but soon goes dead)
If any one has any info to help me out....I would really appreciate it
Thanks
87_300zxT is offline   Reply With Quote
Old Nov 29th, 2003, 10:04 PM   #2 (permalink)
wickedsr20
Red line chaser
wickedsr20's Avatar
Sounds like you have a current drain (short) somewhere in your car causing the dead battery condition. If it's happening as fast as you make it out to be, it sounds like a pretty big one. Hook up everything, then put an ammeter (current meter) in series with the battery (in between the battery and the terminal) and see if it's pulling any significant voltage on the meter. Could be something like an alarm or a radio/amplifier causing the problem or something similar. If you see a current drain on the meter while the car is off, start unhooking circuits (pulling fuses) until the drain goes away and you will have found the faulty circuit. If there is no current drain indicated on the meter, check the voltage regulator or possibly the alternator and charging systems themselves.
Good luck in tracking this problem down.
96 SE-R: SR20VE - bolt ons
97 SE-R: SR20DET 54C - on hold - need $$$
03 Altima SE V6: PR CAI/SS grill/alarm & remote start/100 sf Stinger Roadkill/
19's (need tires)/stereo going in next
wickedsr20 is offline   Reply With Quote
Old Dec 5th, 2003, 08:35 AM   #3 (permalink)
87_300zxT
well, i cant see any pull while my car is off, or on for that matter
This is insane, maybe im using the voltmeter wrong
Hmmmm
Pos wire(red) on the pos wire from batt, neg wire(black) should be grounded on the body or something. Meter should be on the 20 amp dc setting
Is all this correct?
Old Jul 6th, 2004, 11:30 AM   #4 (permalink)
Durett
I had a problem like that on my 85 300zx.
Hello,
I had a problem just like what you are describing on my 1985 300zx. I read a post talking about the turn signal/light switch assembly going bad and causing a light short. I replaced the switch assembly and the problem went away. You will see posts showing how to take the switch assembly apart and repair it - i tried these and had varying success. In any case it never really worked quite right. I would suggest replacing it with a new one if you suspect it. The advice you got on post #2 is a very good way to start after this problem.
Good luck, Jerry.
Durett is offline   Reply With Quote
weird electrical problem??? IXLR8se-r B14 95-99 chassis 9 Jun 1st, 2005 08:28 AM
A/C electrical problem tsi200sx B13 91-94 chassis 8 May 1st, 2003 02:16 AM
Request for help: diagnose electrical problem boost Truck & SUV 7 Apr 29th, 2003 01:56 PM
electrical problem mayers U13 1993-1997 Altima 1 Mar 22nd, 2003 04:59 PM
another electrical problem Laly B13 91-94 chassis 9 Jul 10th, 2002 02:27 PM
