» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Nissan Z > General Z Discussion
General Z Discussion For General Z discussion
Old Apr 21st, 2009, 08:34 PM   #1 (permalink)
Exclamation Please Help, Transmission problem!
Hello,
My transmission has a whine in all gears except 4th (1:1) gear which usually means that the counter shaft bearing is bad (Spdracer explained this to me. Thanks btw) I spoke to the guy who had the transmission before me and he himself is a mechanic who said he never had a problem with it but he would give me my money back which means he probably really did not have this problem. He also looked very shocked when he heard it.
It must be something that happened during install or uninstall (Spdracer explained that this bearing could not be damaged during uninstall or install. It is filled with Pennzoil full synthetic GL4 75-90. It was filled until it ran out of the top. A Z1 TT clutch kit (with new bearings, which make a bit of noise themselves which is kind of annoying but not bad, this only happens in neutral when the clutch is engaged. The throw out bearing was greased before install) was also installed with a newly resurfaced stock TT flywheel.
This sound is driving me insane! please help!
d_flore is offline   Reply With Quote
Old Apr 21st, 2009, 09:25 PM   #2 (permalink)
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
Dump the Pennzoil and try Amsoil or Redline. In the past they have both served me well.
Spongerider is offline   Reply With Quote
Old Apr 21st, 2009, 10:14 PM   #3 (permalink)
different fluid should not cause a whine? This stuff was 50 dollars worth of fluid. Isnt it off that it does not whine in 4th and that it started as soon as a new clutch was put in?
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
