Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > General Z Discussion
General Z Discussion For General Z discussion
Old Feb 25th, 2008, 07:37 PM   #1 (permalink)
WLD_Bill
91 300zx Turbo charger problem?
I took off the turbo inlet pipe to throttle assembly and have pressure on passenger side, and nothing on driver side. The boost indicator shows negative boost and goes to "0" boost when revved up.
The engine is running poorly and I suspect this to be the problem. If it is a froze turbo or whatever, what is involved with replacing it? Where do I get one?
Thanks: Bill
WLD_Bill is offline   Reply With Quote
Old Feb 26th, 2008, 12:48 PM   #2 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
If you have to replace the turbo you need to remove the engine to have easy access. Make sure you have no vacuum leaks and check you ECU for codes?
Spongerider is offline   Reply With Quote
