Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > General Z Discussion
General Z Discussion For General Z discussion
Old Sep 20th, 2005, 01:44 PM   #1 (permalink)
badger
solved "bitch betty" problem!
We could not get 'bitchin betty' to shut up. She kept insisting the driver's door was open even though we could clearly see that it was closed. Deciced to work on rear window leakage instead and when the rear interior trim panel was removed there was a sensor(?) that clips on the inside of the rear lock that had come off. As soon as that was clipped back on, voila!, problem solved.
Hope this info helps someone else.
badger is offline   Reply With Quote
Old Sep 24th, 2005, 06:56 AM   #2 (permalink)
niles_300zx
i'm mad that my 87 doesn't talk
niles_300zx is offline   Reply With Quote
Old May 24th, 2007, 08:12 PM   #3 (permalink)
mark123
I'm sorry to bring this back from the dead but can you tell me what you mean by "inside of the real lock"?
I'm having the same problem but Betty keeps telling me the "Right door is open". I'm going to have to write her up some walking papers. Get to gettin', Betty!
Oh, also the step lights on the door panel stays lit all the time. I assume it is from the same problem.
mark123 is offline   Reply With Quote
Old Jun 11th, 2007, 05:30 PM   #4 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
Send a message via AIM to Zen31ZR
Remove the rear trim panel on that side, look inside and towards the front of the car and you should be able to see the rear "wall" of the door jam. The sensor clips in there.
1992 Yamaha FZR 1000. 145 Hp, all stock..
Zen31ZR is offline   Reply With Quote
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 08:18 AM
Solved my overheating problem... Thanks for the help! alkon GA16DE 1.6L Engine 1 Jan 30th, 2005 08:23 AM
Overheating problem.. What should I do next? alkon GA16DE 1.6L Engine 4 Jan 25th, 2005 10:05 PM
I just solved the problem in Iraq Sentra_Industies Off Topic 51 Feb 20th, 2004 12:22 AM
