Blinking Check Engine Light - Nissan Forum
General Maxima Discussion For general Maxima discussion
post #1 of 5 Old Mar 3rd, 2010, 09:15 PM Thread Starter
Question Blinking Check Engine Light
First time posting, hopefully I can find some help.
Two weeks ago the alternator went on my 2000 Maxima GLE. I replaced the alternator (fun). Immediately following the swap out the car began to run rough, the whole accelaration wall at 3500 RPM, bog at start, whole nine yards. After searching the internet found out the problem might be the MAF. So replaced the MAF and rather than take it to a dealership to have the ECM updated I tried the disconnect the battery and tap the brake for a half an hour trick, hoping that would work. Well drove around for a couple of days and the car had tons of new power felt like a new car. Did notice a fuel smell once the car was sitting in the garage after driving. Then a few days ago the CEL started blinking periodically. Again after looking the internet for a solution found some sites that said this is very bad and could potentially ruin the cat converter (don't want to have to replace that). So when the CEL isn't blinking it is on. Pulled the codes tonight and got 0301 cyl. one misfire, 1320 ignition system and 1126 thermostat.
My question is can any of the pulled codes be related to the new MAF that didn't have the updated ECM or are all these new issues. Mind you the car didn't run rough (bog down) before the alternator went. Any help or insight would be greatly appreciated.
Thanks in advance.
jmf265 is offline
post #2 of 5 Old Mar 3rd, 2010, 09:27 PM
Post Freak
Faja's Avatar
Yes, if your light is blinking you should not drive the car as it could cause more damage. As for the codes, I don't believe they are related to the MAF and I don't think you need to update your ECU when you change it either. It sounds like either a fouled up plug(s) or ignition coil problem so check those items first............and QUICKLY!!!!
Faja is offline
post #3 of 5 Old Mar 3rd, 2010, 10:03 PM
MODR H8R
JNCoRacer's Avatar
Send a message via Yahoo to JNCoRacer
P0301 and P1320 will be related. Like Faja said, check your plugs first as they are the cheaper and easier parts to replace if needed. If those look ok then you go on to testing the coil packs. If those test ok you move on to testing the injectors.
JNCoRacer is offline
post #4 of 5 Old Mar 7th, 2010, 08:07 AM Thread Starter
So I pulled the spark plugs and they were Bosch Platinum rather than the nissan recommended NGK Platinum, so those were replaced I also replaced the #1 coil which fixed the 0301 code. But the 1320 code is still there. Can anyone help?
jmf265 is offline
post #5 of 5 Old Mar 7th, 2010, 06:24 PM
Post Freak
Faja's Avatar
Here's an interesting article re DTC 1320 on Nissan Maxima - this may help you
Nissan Maxima DTC P1320
Faja is offline
  Nissan Forum > Maxima > General Maxima Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
