Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Maxima > General Maxima Discussion
General Maxima Discussion For general Maxima discussion
Old Dec 12th, 2006, 12:49 PM   #1 (permalink)
jerbremser
Angry Fuel Problems
I have a 1993 max DOHC. i have replaced the Fuel filter, spark plugs, and oil, which had a gas smell to it.
After i did this the car started up right away for about 20 minutes and then died on me and i could not get it to start again. I am thinking i have to either replace the fuel pump or the fuel relay switch. What ideas does anyone have for why my car wont start back up? When i try to start the car it sounds like either there is not enough fuel getting to the motor or the motor is flooded and cant start. She sounds like she wants to start and ignite but just doesn't.
Please give me your ideas.
jerbremser is offline   Reply With Quote
Old Dec 12th, 2006, 07:23 PM   #2 (permalink)
RedHead7
RedHead7's Avatar
I do not know that much about the fuel system, but could it be your fuel injectors??
Minor Modifications To My Car: Razo Shift Knob, Eibach Sportline Springs, KYB AGX Shocks, SS AutoChrome Header, Custom Cat-back, Injen CAI, B&M Short Shifter -- More to come soon!
RedHead7 is offline   Reply With Quote
Old Dec 12th, 2006, 07:42 PM   #3 (permalink)
ilikespeeding
It's most likely a fuel problem if the car doesnt start back up. Does the maxima have a straiter valve on the fuel line? If so, after the car stalls, push in the valve to see if there is any pressure on the line. If there is pressure, it might be a clogged injector or two. Simply striking the injectors with a wrench with about the same force as you would use to hit a pack of cigarettes on you palm would clear the injectors of debris. If there is no fuel pressure in the straiter valve, then you might be looking at a pump or relay. If you dont have a straiter valve, then follow the test for the relay; if the relay is good and there is no pressure, it's a pump problem.
To test the relay, when you put the ignition in the on position, you should hear the click of the relay. If you dont hear it after about 2 seconds, bad relay.
1990 Eclipse GSX - Money Eater
1996 Eagle Talon TSi - Wrong wheel drive
1996 Sentra GXE - Daily Driver
ilikespeeding is offline   Reply With Quote
Fuel Filter? ghost_ryder35 B15 2000-2006 14 Mar 28th, 2006 11:09 AM
LOL@FPR bridrive55 S13 240SX 1989-1994 1 Feb 24th, 2006 04:44 AM
1984 300zx fuel pump problems PLEASE HELP!!! mlaxton Z32 Chassis 300ZX 0 Aug 25th, 2005 02:59 PM
Starting Problems/ Fuel injector and ECM.....Help!! seaofprajna U13 1993-1997 Altima 3 Jul 25th, 2004 01:07 PM
Fuel Pressure Regulator 0341TODD Z31 300ZX(T) 16 Jun 29th, 2004 08:10 AM
