depends on the part. most of the time, ill try n get it from a nissan dealer. but if it something like a mirror, antenna, or a trim piece, ill check out one of the online dealers like autopartsreplacement.com.
also, ebay, and even better, someone on here parting out a car on the forums is most likely a better deal. whatever works best i guess..
Originally Posted by RoadWarrior - ocforums.com
Yes, SATA is faster however..... putting full spec formula one tires on a 1.6L stock honda civic will not make it capable of 200Mph......
on car-part.com, what is the term/words i look up when searching for an, let's say, 1995 j30 lsd? they dont even have lsd on the list. is it called another name. it isnt limited slip differential either, i looked those words up. no success there. any help?
thanks
Wat i found was, Differential assembly...or Carrier.. are the terms to search under..
I would see tho, if you have any junkyards in your area, like preffereably Pick-your-part/pick-a-part...same thing..
They are wayy cheaper than anything youll find online most of the time..
I found a private junkyard here in So.Cal, the guy only wanted $125 for a
N/A 300zx differential.
