Go Back   NissanForums.com :: Nissan Forum > General > General Discussion
General Discussion For general Nissan discussion
Old May 17th, 2004, 12:35 PM   #1 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
How to: Battery Relocation
I did the battery relocation in my SE-L just like I did in the sentra, I took pix this time to show everyone how it's done.
Parts:
>Optima battery (I highly recommend the 34/78 model in yellow or red top b/c of the side terminals)
>Battery tray and tie down, search google for an optima-specific one.
>Drill bits and Gromets. 1/4" bit for bolts, <1/8" bit for screws, 1" bit for 1/0AWG cable or 1/2" bit for 2AWG.
>Cable, 6 feet of 4AWG, 18 feet of 2 or 1/0AWG. 2AWG is the minimum recommended for the main positive wire. I used 1/0AWG which is THICK.
>Ring terminals, heat shrink, and adaptors for the optima's side terminals (autozone and home depot)
>Fuse and holder (150A is good)
>Butt-connector to tie together the cables.
Step 1:
Remove all carpet in trunk from around the battery area. You will need a custom battery tie-down (you can find one on the internet). This is a billet aluminum one specific for the Optima 34/78 batt. Wedge the tie-down in place and drill holes to mount. (be sure not to drill into anything under the metal, I only used 2 screws):
Step 2:
Drill holes to run the wire. You will need a hole in the trunk just above the seat belt and one behind the kick panel to run the cable into the fender. Be sure to gromet the holes:
Step 3:
Prep wire. Cut the 4AWG grounding wire into 5 pieces: 4-1ft and 1-2ft, strip ends and crimp on ring terminals. Finish off with heat shrink. The main wire needs a foot long section between the batt and the fuse, then the other 17 feet will run up to the engine bay. Attach the ring terminals to the wires except for the part of the wire that will be in the engine bay:
Step 4:
Grounding. The 1 foot wires must be attached to the car with bolts (be sure to shave the paint underneath the rings). The 2-foot section must replace the stock ground between the body and the engine block:
OBSERVE BLUE WIRE:
Step 5:
Running main cable. Run the cable under the carpet through the cabin on the driver's side, it'll go through that hole, through the fender (may need to remove lining) then into the engine bay:
Step 6:
Mount battery. Mount the fuse in a convenient place, put battery in, and hook up all wires (KEEP FUSE OUT MAKE SURE MAIN WIRE IS NOT LIVE UNTIL EVERYTHING IS HOOKED UP PROPERLY)
Step 7:
Stock fuse holder(s). The stock fuse holder needs to be mounted somehow now that it's not connected to the battery tray. What I did was drill 4 small holes and put in 4 screws, the screws could hold down zip ties (I USED WASHERS AS WELL TO HOLD THE ZIP TIES ON):
Step 8:
Connect main power. You will need the 1/0AWG butt connector to connect up the wires in the engine bay. It holds the wire in with a hex screw, then complete with heat shrink:
Step 9:
Connect fuse and enjoy. You will need to cut off some trunk carpet, but this is the finished product:
Engine bay (once again):
Ninety-Nine SE-L is offline   Reply With Quote
Old May 17th, 2004, 01:45 PM   #2 (permalink)
Nuskool
Right By DA Beach....
Nuskool's Avatar
Yeah great job and good pic. I did mine a while back but without a kit. Looks great
In the process...
Nuskool is offline   Reply With Quote
Old May 17th, 2004, 04:12 PM   #3 (permalink)
danifilth
NisMopar
danifilth's Avatar
Send a message via AIM to danifilth
this write-up shall live forever!!!
I See Someone Has A Bad Case Of The Hyundais.......................
danifilth is offline   Reply With Quote
Old May 17th, 2004, 06:32 PM   #4 (permalink)
jingjing
wow, that looks really good. eventually i will do that to my se-r.
Later, Jay :)
91 Sentra E - DD
93 Sentra SE-R - jdm powered
04 Frontier CC,LB
jingjing is offline   Reply With Quote
Old May 18th, 2004, 01:31 PM   #5 (permalink)
amperes
so the ground wires are the blue ones right....are they just grounded? i dont understand how the negative terminal is running all the way to the back.?
the picture doesnt show it. it only shows two of the thick cables at the end, are those both positivew or is one of those negative also...?
amperes is offline   Reply With Quote
Old May 18th, 2004, 01:40 PM   #6 (permalink)
Ninety-Nine SE-L
Please Shift Here
The 4 blue wires are the 4 grounds. They are jus attached to the body. The positive wire is the silver one and it is on a fuse (the fuse is very important if you are in an accident..it already proved itself on my last car when the car was totaled):
I chose 4 little wires rather than one big wire b/c the week point in such a short length of wire is where it makes contact with the body.
Old Jun 12th, 2004, 07:57 PM   #7 (permalink)
Ninety-Nine SE-L
Please Shift Here
arise my lovely writeup.
(someone jus asked me about it)
Old Jun 17th, 2004, 12:53 PM   #8 (permalink)
OniFactor
OniFactor's Avatar
Send a message via AIM to OniFactor
hey, do you mind if i yoink this, to put on another forum? i'll relocate the pix, so as not to eat your bandwidth..
why oh why can't i find a good nissan for myself?
OniFactor is offline   Reply With Quote
Old Jun 17th, 2004, 01:56 PM   #9 (permalink)
Ninety-Nine SE-L
Please Shift Here
what forum? You can keep the original image location, I get unlimited bandwidth on photobucket.com.
Old Jan 4th, 2006, 05:24 PM   #10 (permalink)
aminidab
Destroyer of Engines
aminidab's Avatar
Ninety-Nine SE-L, where did you get the connector shown in step 8?
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
aminidab is offline   Reply With Quote
Old Jan 4th, 2006, 08:19 PM   #11 (permalink)
Ninety-Nine SE-L
Please Shift Here
car audio shop.
Old Jan 12th, 2006, 12:43 AM   #12 (permalink)
Sentrixx
Nissan Addict
Sentrixx's Avatar
Send a message via AIM to Sentrixx
So what is the whole point of doing this anyways. I still havn't figured it out.....
Wayne.
Cloud White 99 SE-L
my whip now has mods :tongue:
http://www.cardomain.com/ride/805495
Sentrixx is offline   Reply With Quote
Old Jan 12th, 2006, 01:35 AM   #13 (permalink)
Ninety-Nine SE-L
Please Shift Here
this is why:
Old Jan 12th, 2006, 09:15 AM   #14 (permalink)
Sentrixx
Nissan Addict
Sentrixx's Avatar
LMAO! Smartass!
Yeah... well not everyone has a VE to stand next to either. :P
Wayne.
Cloud White 99 SE-L
Old Jan 12th, 2006, 12:06 PM   #15 (permalink)
NotAnotherHonda
Have I Hit 12's Yet?
NotAnotherHonda's Avatar
justin you are one ugly bitch! haha
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
NotAnotherHonda is offline   Reply With Quote
battery relocation b15sentra QG18 1.8L Engine 4 Mar 22nd, 2004 11:45 AM
Parts for battery relocation OmarMiPi GA16DE 1.6L Engine 2 Feb 15th, 2003 12:29 PM
Recommended battery DNYC B11/B12/KN13 82-90 chassis 21 Feb 4th, 2003 09:37 PM
battery relocation kit? JeffB200sx B14 95-99 chassis 10 Oct 23rd, 2002 03:36 PM
