Does hjgher octane gas cause more carbon build up? - Nissan Forum
General Discussion For general Nissan discussion.
post #1 of 12 Old Jul 23rd, 2003, 07:58 PM Thread Starter
Nissan Addict
Alright, I know this question has been asked many many times, but I only want to know, will using 89 or 91/93 octane in my sentra 1.8 cause more carbon build up than using just 87. I know that there will most likely be no performance gain and no better gas mileage increase. It used to be, some say anyways, that the higher octane gas had better cleaners in them, but now all gas is supposed to be the same aside from cleaners. I've heard that using higher octane gas will cause more carbon build up, but others say that using a slightly higher octane rating, say 89 instead of 87 may fight off the knock/ping caused by a bad batch of gas and offer a little more protection. I know I'm opening a can of worms here, but will higher octane harm my engine? That I guess is the ultimate question.
dschrier is offline
post #2 of 12 Old Jul 23rd, 2003, 11:06 PM
P.O.S. Truckdriver
Katana200sx's Avatar
actually higher octane gas will help clean your engine out some bc it burns hotter than a lower octane gas.
Need parts?
91 SE-R Partout
96 200SX SE Partout
Katana200sx is offline
post #3 of 12 Old Jul 24th, 2003, 09:54 AM Thread Starter
Nissan Addict
I've read before that higher octane gasoline used in a car which doesn't require it will cause more carbon build up due to the slower burning of the fuel. Of course this could have been stated long ago when fuel and engines were much different than they are today.
dschrier is offline
post #4 of 12 Old Jul 24th, 2003, 11:46 AM
bitter old man
bahearn's Avatar
Higher octane gasoline does not burn hotter.
Modern street high octane gas will take a long time to carbon up your combustion chamber. Race gas is s different story since they typically use aromatics to attain their octane gain. The aromatic components are what coke up in your engine.
Bruce in Houston
bahearn is offline
post #5 of 12 Old Jul 24th, 2003, 12:27 PM Thread Starter
Nissan Addict
So would running 89 octane in my car cause any harmful side affects to the engine in the lifespan that I might own the car for?
dschrier is offline
post #6 of 12 Old Jul 24th, 2003, 04:02 PM
bitter old man
bahearn's Avatar
The only harmful side effect would be your artificially low bank account. The only reasons to go with higher than 87-octane are bumped timing or already-coked cylinders.
Bruce in Houston
bahearn is offline
post #7 of 12 Old Jul 27th, 2003, 04:34 AM
johnebp's Avatar
from what i've read...
Regular octane (89) is recommended for most cars. Suped up and turbo cars need the higher octanes to prevent knocking.
EVERY level of octane contains the same amount of carbon deposit preventing additives, this is by national law.
Fuel system cleaners supposedly do work, once or twice a year put a bottle in your system to help against carbon deposits.
So basically, if you're not knocking, then you're fine.
'88 Z
johnebp is offline
post #8 of 12 Old Jul 27th, 2003, 11:29 AM
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
actually, i believe that it should burn cleaner with a higher octane, i know cars run better with higher octane.. i dont use anything less than 89...
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline
post #9 of 12 Old Jul 27th, 2003, 02:04 PM
Send a message via AIM to bump
on some cars stock you must use high octane gas. they have high compression ratios, like my moms acura that she killed. it still runs, but it smokes like a fucking train, and its only a 96. its because shes too chep and used 87 when she needed premium. it even says that on the dash
bump is offline
post #10 of 12 Old Jul 27th, 2003, 04:25 PM
johnebp's Avatar
if you modify your engine, ask someone, if not, check your car's manual, it'll tell you.
'88 Z
johnebp is offline
post #11 of 12 Old Jul 28th, 2003, 12:42 AM
Send a message via AIM to ForsakenRX7
High compression cars, turbo cars, and supercharged cars need high octane to prevent pinging and detonation. The standard naturally aspirated vehicle (like a stock 200sx for example) does NOT. Yes, believe it or not using high octane in a normal car can cause carbon build up over time because when using Supreme or hi octane in a non turbo, the higher octane makes it more difficult to burn all of the fuel allowing for excessive carbon. Trust me, I drive a rotary car. Carbon build up knowledge is key to a rotaries survival.
ASK ME ABOUT MY TRIANGLE PISTONS
ForsakenRX7 is offline
post #12 of 12 Old Jul 30th, 2003, 08:55 AM
bitter old man
bahearn's Avatar
Rotaries coke because of oil leaking past the end seals.
Modern high-octane gas won't coke up like the old formulas.
Psulemon, you'll change your BELIEF after reading "The Internal Combustion Engine in Theory and Practice" by Charles Taylor. There are two volumes, Vol. 2 will suffice for this conversation.
Bruce in Houston
bahearn is offline
  Nissan Forum > General > General Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
