Go Back   NissanForums.com :: Nissan Forum > General > General Discussion
General Discussion For general Nissan discussion
Old Jun 11th, 2002, 10:47 PM   #1 (permalink)
manesg
Posts: n/a
Unhappy HELP G20 Warning Lights
I own a 1992 Infiniti G20.
Today I noticed after the car is started three warning lights stay on:
Brake Warning
Battery Warning
Anti Lock Brakes Warning
I can't figure out why they stay on all of these systems
are functioning perfectly and the Service Manual does
not talk about this at all.
Any help would be appreciated.
I have tried:
ABS diagnosis
Ground checks
Thanks
Gavin W. Manes
Old Jun 12th, 2002, 12:42 AM   #2 (permalink)
CarbonBlack200
Platinum
CarbonBlack200's Avatar
Send a message via AIM to CarbonBlack200
Exclamation Warning
I think it means your battery is dieing. Your alternator probablly isn't charging right now. It is showing break warning lamps because your brake system will not function like how it should when you have no electrical power. Did you notice your windowshield wipers and power window is rolling up/down slowly? If you notice that, that means your battery is dieing. Check your alternator. I would check and fix it A.S.A.P.
CarbonBlack200 is offline   Reply With Quote
Old Jun 12th, 2002, 12:16 PM   #3 (permalink)
p10driver
Nissan Fanatic
Yes! On most cars when the alternator dies some lights stay on becouse of the way the check system works.
Go and check all alternator wiring and measure the voltage on the battery it should be about 13-14V when the car is running.
p10driver is offline   Reply With Quote
Old Jun 15th, 2002, 05:42 PM   #4 (permalink)
manesg
Posts: n/a
Wink
Indeed my battery was only putting out a little over 10 volts, because it had a dead cell in it. Also my alternator went bad probable because of the bad battery.
Here is the story:
I had a Optima spiral cell battery paid $87 for it at Pep boys. But when i bought it they did not have the one that fit my car (poles are reversed). So I was instructed to buy the same size and just put the battery in backwards. I fit and I did not see anything wrong with this.
Here is the funny part:
The Optima is the one previously mention that had a bad cell. So I went back to Pep Boys to get a new one (24 month warranty).
The guy FREEKED OUT that I had the battery was in backwards. Saying that "How do they expect me to warranty a battery that is in backwards." Of course by backwards I mean 180 Deg rotation so the positive pole was in the right place. Bicker, Bicker Bicker ... more Bicker, but I never had to the Bickering was between the two managers. I just let them argue. Finally the one said QUITELY in my ear just take this one and walk out the door. So I did.
Later
Dash warning lights The_Tango U13 1993-1997 Altima 15 Sep 28th, 2005 07:29 AM
Battery and brake warning lights CrunchyCookie B14 95-99 chassis 7 Nov 30th, 2002 07:54 PM
G20 "fog" lights in a B-14 redviper98 B14 95-99 chassis 3 Nov 14th, 2002 12:41 PM
My dashboard warning lights have gone crazy! gnomer B13 91-94 chassis 3 Nov 4th, 2002 11:49 PM
warning lights turning on without anything wrong? Exile B11/B12/KN13 82-90 chassis 5 Sep 4th, 2002 10:00 PM
