» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Altima/Stanza > General Altima/Stanza discussion
General Altima/Stanza discussion For general Altima/Stanza discussion
Old Apr 24th, 2005, 01:51 AM   #1 (permalink)
gosooner
Altima: Starting Problem: Starts after 2 or 3 hrs rest:
The car runs fine. Once driven for a while, and left it for 2 or 3 minutes, and then if I start it, its not starting again. After a while (leaving it for 2 hrs), the car starts with no problem. All this happened at the Pizza hut, I went in paid and got the pizza, and come back to car to start, I was shocked to see it was not starting. Thought you may advice on this.
It was a Nissan Altima 96, I have no idea whats wrong with the car. Its not battery problem since it gave me the same problem before, and it started on itself the next day.
gosooner is offline   Reply With Quote
Old May 5th, 2005, 08:55 PM   #2 (permalink)
chrisdorf
I have been having the same problem...it warms up, then won't start if it sits a few minutes...then it will start when it cools down...
Anybody have answers?
chrisdorf is offline   Reply With Quote
Old May 25th, 2005, 11:34 PM   #3 (permalink)
merkerguitars
Most likely its the starter. Sometimes when the windings go bad in it and the starter gets warmed up they won't turn.
merkerguitars is offline   Reply With Quote
Old May 26th, 2005, 06:38 PM   #4 (permalink)
gosooner
I had this problem only twice on the same day. After that I didnt have this problem. I had it checked by my mechanic, he says there is no problem with the car and it should run good. And it is so. Till now I didnt have any problem. I am waiting on a chance that it wont occur again. I dont know what the real problem is.
Though my friend told me that it happens due to the distributor shaft. It may cost $250 for the distributor plus the labor. I will do it if it happens again.
Please get back to me if you have found anything else regarding your car problem. Thanks.
Old May 26th, 2005, 09:59 PM   #5 (permalink)
chrisdorf
I took off the distributor cap, the cover under the distributor cap that covered the crankshaft position sensor, and cleaned it all with carb cleaner very completely, and I have not been having any problems since. I also changed out all the plugs, wires cap, rotor, cap...
Old Jun 25th, 2005, 08:31 AM   #6 (permalink)
Tabo
One thing it could be is the fuel pump. I had a problem with restarting after driving, happened about 4 times in as many months had to wait longest about 1.5 hours before it would restart, took to the dealer and they replaced the fuel pump and it never happened again.
Tabo is offline   Reply With Quote
Old Jun 27th, 2005, 01:17 PM   #7 (permalink)
chrisdorf
Ever since I cleaned the crankshaft position sensor and surroundeding area very carefully, twice, and changed out plugs, wires, plugs and distributor cap and rotor, it has not done it since!!!!!!!!
Old Jul 21st, 2005, 06:00 PM   #8 (permalink)
jserrano
Good fix. The distributor o-ring tends to foul and leaks oil into the camshaft sensors.
jserrano is offline   Reply With Quote
Old Jul 24th, 2005, 12:24 AM   #9 (permalink)
chrisdorf
It was more trial by necessity! The O ring, if you mean the one under the distributor cap and over the sensors, was stretched and distended...letting oil leak in. But it could have been the distributor O ring...
It works now!
Old Apr 14th, 2007, 04:20 PM   #10 (permalink)
Stockwell
It works now!
crisdorf:
I own a 96 Nissan Altima. My problem is oil leaking thru the distributor. Leaks about 2 thimbles in 2 days during short drives around town.
. had used distributor installed - same problem.
. Auto Zone person said that if PCV Valve is stopped up, could cause pressure in crankcase and force oil out thru dist. - replaced PCV Valve - no help.
I am wondering if I have an O-Ring problem as you suggest?
Have you seen or heard of oil leaking thru the distributor?
Do you have any advice. Any help is greatly appreciated.
I don't do my own Nissan repairs. And not very knowledgeable.
Email: wdstockwell@gmail.com
Stockwell is offline   Reply With Quote
Old Apr 14th, 2007, 04:27 PM   #11 (permalink)
Stockwell
jserrano:
I sent this same msg. to crisdorf and am waiting for a response.
Thought I would send to you as you speculated O-Ring problem!
. had a used distributor installed - same problem.
Old Apr 16th, 2007, 02:18 PM   #12 (permalink)
chrisdorf
oil under distributor cap...
I have not had the problem since I cleaned off the position senson UNDER the distributor cap...oil was getting in and, I believe, stopping the sensor from doing its job.
It has not happened since 2005 after I did that, so I think that was it...I placed the O-ring so it was tight UNDER the distributor cap.
chris dorf
crisdorf:
Originally Posted by Stockwell
jserrano:
Problem starting - battery drain? casagrande Truck & SUV 5 Jun 24th, 2006 12:28 PM
Freeze Starting Problem with GA16DE 1.6 georgyop GA16DE 1.6L Engine 8 Jan 11th, 2005 08:58 PM
starting problem on my 97 sentra archer98 GA16DE 1.6L Engine 6 Nov 23rd, 2004 07:43 AM
Altima ignition problem shrkb8 New Member Forum 0 Jul 1st, 2003 09:01 PM
Starting problem!?? 93altima U13 1993-1997 Altima 2 May 7th, 2003 08:51 PM
