Is there any other fuel pump ( besides oem ) that will fit on 97 Altima. I'm not talking about aftermarket ones either, but rather fuel pumps from other nissans or even different brand.
The 300Z TT fuel pump does fit with a little modification to the pickup but it is much higher flow and the pump is noisier. I don't think that I would recommend it as a direct replacement for even a moderately modified normally aspirated car. I would suggest the factory replacement although I'm not sure why your adversion to it...
Troy
SHIFT_Happiness
1992 S13 240SX SE Fastback KA24DE 5 spd - Type X Aero & Seibon Carbon Hood & Hatch -soon GT28RS
1993 U13 Altima SE KA24DET 5 spd w/ Nismo LSD - A high hp FWD can be fun (GT30R Turbo inside)
1990 Z32 300ZX VG30DETT 5 spd - 600HP & Very Civilized (working on twin GT28RS turbos)
Still trying to import a 1988 R31 Skyline GTS-R w/ RB20DET-R - only 800 produced (legal under show/display regs)
Troy
Thanks for the info Troy. I just installed a nismo fpr and a gauge. what fuel pressure would you suggest running between 9 and 12 psi?
also, considering I got 50 psi out of my pump at idle, (not running that much) I'm thinking I may not need to upgrade my pump yet.
I love the Nismo FPR!
What size are your injectors? That will help to determine the fuel pressure.
Troy
SHIFT_Happiness
300Z and the walbro unit pump the same 255lph, you can get a direct drop in walbro unit or have to splice wires for the 300Z. I have the 300Z and honestly the only reason I got it was because it was on sale and was cheaper than the walbro unit at the time.
Troy
I'm running the 370's.
and while I have you attention, Mr.Cthunder and I have been going back and forth about where to take fuel pressure readings. he claims that you would want to run an inline gauge on the return side, which doesnt make any sense. I have mine on my feed side. Haynes, my shop key at school, and my instructers all say that fuel pressure readings are to be taken on the feed side. that makes perfect sense.
Well the 370 cc should work just fine at between 45-50 psi. Which will give them about a 10 psi increase which translates to a new flow rate of approx. 475 cc. This will cut the duty cycle percentage and should safely supply the engine needs at 12 psi of boost. I would still be weary of sustained boost in the 12 area because of the very high cylinder pressure and stock internal KA (head gaskets, carbon hotspots, etc.) unless you run a race gas blend to raise the octance. Just my thoughts...
Think of the regulator like a electronic resistor, which to measure the supply you need to be forward of it to read the force (pressure) correctly. You should place the gauge as close to if not on the fuel rail to have the most accurate measurement of the supplied injector pressure when adjusting the regulator. On the other side of the regulator, you are just reading the residual pressure (resistance) in the return line back to the tank. Sorry Carl...
Troy
SHIFT_Happiness
