check engine light code -P0340- - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Altima/Stanza > General Altima/Stanza discussion
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
General Altima/Stanza discussion For general Altima/Stanza discussion
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Jan 5th, 2013, 11:17 PM   #1 (permalink)
today i bought a 1996 nissan altima SE and everything was fine with it when we checked it out.. but then 8 hours later the check engine light randomly went on... i took it to autozone to get the codes checked and it came up as:
-P0340-
Definition:
Camshaft position sensor (CMP) circuit- bank 1 probable cause.
1: open or short circuit condition
2: poor electrical connection
3: weak battery condition
4: Faulty CMP
I also have a small oil leak... not sure if its bad or not, but i plan on checking it out on my next day off.
another thing, there is a small ticking noise coming from one of the fuel injectors, the noise comes and goes, but im also not sure if it is exactly coming from that area..
djziddi is offline   Reply With Quote
Old Jan 5th, 2013, 11:32 PM   #2 (permalink)
NF Mod
Send a message via AIM to smj999smj
The cam position sensor is built into the distributor. It's not uncommon for the shaft seal inside the distributor to leak oil and create issues; often you will see evidence of residual oil laying inside the distributor cap when you remove it. Fix is to replace the distributor assy. It's not unheard of to hear some ticking from the fuel injectors; usually it's a non-issue, but you could try running some fuel injector cleaner through them. Usually the professional-type fuel injection service in which the engine is run strictly on an injection cleaner in a self-contained, pressurized canister (ie 3M or BG Products) works much more effectively than a gas tank additive.
smj999smj is offline   Reply With Quote
Old Jan 6th, 2013, 01:27 AM   #3 (permalink)
alright that distributor cap should only be about 20 bucks right? or do i need to get the whole thing replaced? and how would that be effecting the camshaft sensor that the code reads?
and ill try that fuel injector cleaner too, sounds like good advice, ill get back with you on how it all turns out!
Old Jan 6th, 2013, 01:32 AM   #4 (permalink)
jdg
The Judge!
The whole thing.
Cam sensor is in the distributor itself.
99% of the questions that are "STRANGE" have a dirt simple answer...usually answered by a dirt simple search.
NISSAN GOOGLE
Is it just me, or does the majority overlook the obvious?
Somebody ate a whole bag of dumbass for breakfast.
Why do people continue to run a vehicle when a warning light comes on or starts flashing? Isn't that a clue that something is wrong and you probably should NOT drive it?
Is this whole car driving thing really freekin' brain surgery?
Here's something new for the crowd/clowns...
"A little bit of Google goes a long way!"
Ever notice the one post wonders for info on turbo'ing a GA16 are never heard from again after they figure out the cost???
And if you can read this, you don't need glasses! :)
And yes, I am diggin' it...
jdg is offline   Reply With Quote
Old Jan 6th, 2013, 02:19 AM   #5 (permalink)
i search online to buy a camshaft sensor and cant find one? i came across something about them not making them? or those kinda cars dont have them?
and do you think thats why my car is leaking oil? ill check where the car is leaking oil at when i have daylight..
Old Jan 6th, 2013, 02:26 AM   #6 (permalink)
well i do see "crank" shaft position sensors but not "Cam" shaft position sensors, is there even a diference? or they both the same?
Old Jan 6th, 2013, 03:11 AM   #7 (permalink)
jdg
The Judge!
You're not reading and/or haven't done any reading yet...
The cam sensor is in the distributor itself!
NISSAN GOOGLE
Old Jan 6th, 2013, 12:21 PM   #8 (permalink)
which means i cant replace the sensor itself? i have to replace the whole distributor?
i took a look at the distributor and saw that it is brand new, there is no oil leaking in the cap, its clean and spotless..
i dont understand whats wrong... it runs perfectly fine, i just need to pass emissions
Old Jan 6th, 2013, 12:23 PM   #9 (permalink)
i took a look at the cap like you said, there is no oil leaking inside, it looks like the distributor has been replaced before..
i dunno if i should replace the whole thing or not.. it seems fine to me.. and there is no way i can replace the camshaft sensor itself huh? id have to just replace the whole dis?
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
