Hello fwellers,
I'm going to assume that the Altima Coupe is a 2008. ;-)
The keyless entry, I believe, is only really activated the moment you press the button on the door handle. As well, the car recognizes that you are in the car only when you 'sit' at the drivers seat. At that time, the car sends out the signal to verify that your key fob is the correct one, and allows you to use the desired function.
When leaving your car for 2 weeks, or even a whole month, the keyless entry system should not drain your battery at all. If it would, it would be such a minuscule amount it would surely not take more than a tenth of an amp from your battery, and that would be regained the next time you drive your car.
If you think about it your car has to, 24/7, listen for your remote to send a lock/unlock, etc. signal to your car. That 'signal receiver' runs all the time, in every car that you own. The keyless entry is the same idea, and I would have to say you will be fine for the two weeks that you are gone.
I hope that this has answered your question, and I hope that your wife (and you) enjoy your Altima Coupe!
