[quote=jperron]I have a 1995 Altima- Car quit and will turn over but no spark. No power to the ECM - Relay is good. Any ideas?[/QUOTE
So the engine cranks but will not start or crank over right? Is the engine light on or did you scan the ECM for any stored codes, thats the first place I'd start. If there's no code then its an electrical or fuel issue. Check the battery and cables and starter, then check the fule pump. Like I said see if there's a code in the ECM, even if the engine light is not on.
Frank
