Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > General Altima/Stanza discussion
General Altima/Stanza discussion For general Altima/Stanza discussion
Old Jul 8th, 2006, 07:24 PM   #1 (permalink)
MickeyKnox
Nissan Fanatic
how does engine go bad after high millage?
So I have 1995 altima with 190K millage.
I take good care, change oil, filters etc.
why do engines with high millage break usually?
what exactly happens to those high millage engines.
how much more will my car drive?
thanks.
MickeyKnox is offline   Reply With Quote
Old Jul 8th, 2006, 07:56 PM   #2 (permalink)
Asleep
Super Mod - ALL the time!
Asleep's Avatar
Send a message via AIM to Asleep Send a message via Yahoo to Asleep
you can hope, with regular maintenance, to go about 250k with a ka. possibly more. there are ka's out there with more than 300k. i personally had an engine with 165k miles on it, that, when i tore it apart, still had the cross hatching from the original boring of the cylinders. no noticeable cylinder wear either.
on most high mileage engines, the cylinder rings are wearing out, the cylinders have an egg shape worn into them, the bearing measurements are larger. not to mention chain tensioner wear and valve wear and tear. taking good care of it though, will increase its life expectancy.
Nissan Moderators needed
contact Sassan @ www.SUPERNISSANS.net
http://www.cardomain.com/id/our rides
Asleep is offline   Reply With Quote
Old Jul 8th, 2006, 10:57 PM   #3 (permalink)
MickeyKnox
Nissan Fanatic
so is replacing cylinders and rings something doable at home?
or special equipment is needed.
basically is it an expensive procedure to get the high millage engine running
again.
or by that time the whole engine needs to be rebuilt.
also is it ok to take off the top cover of the engine(where the spark plug entries are) on 1995 altima. I heard if I take it off then I will screw up some gasket alignment.
thanks.
Old Jul 8th, 2006, 11:02 PM   #4 (permalink)
Asleep
Asleep's Avatar
the cylinders you cant replace. but you can have them honed. the cylinders would need to be measured first though. you can have the cylinders bored (cut bigger) and new pistons and rings installed. but then, you might as well have the bearings for the crankshaft and rods replaced as well. all of this costs a bit of money though, as you can expect. youre probably actually better off just finding a lower mileage engine from a private party or salvage yard. i found my first replacement engine at a salvage yard for 950 dollars and it only had 500 miles on it.
replacing the engine would be cheaper and create less downtime for you.
Engine mounts gone bad.....best place to buy the engine mounts? bentley98 L30 1998-2001 Altima 3 Jan 31st, 2005 03:36 PM
Any pics of a high pressure A/C hose on a z24 engine? DanaCat Truck & SUV 6 Jan 21st, 2005 02:58 PM
Bad Gas Millage Help me Skoodles GA16DE 1.6L Engine 24 Oct 18th, 2004 11:08 AM
Will a 95 Altima engine work in a 91 240sx 91240sx S13 240SX 1989-1994 1 Aug 3rd, 2004 03:16 AM
engine rough at high rpms brucek2 B13 91-94 chassis 0 Dec 15th, 2002 06:01 PM
