Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > General 240SX/Silvia/S12 200SX
General 240SX/Silvia/S12 200SX For general 240SX/Silvia/S12 200SX discussion
Old Mar 12th, 2005, 07:10 PM   #1 (permalink)
Tricky3D
Unhappy 87 200sx xe starting problem
I can't figure this out... My car was running fine about a week ago, when I had a guy stop buy to look at buying it... it wouldn't start. The battery is brand new and so is the starter. The cap and rotor are new as well. I am not getting any spark from the coil. I have read the wires to the ignition switch and they all read out good. Since the start of this problem the security system light wont light up when the door is open, the head lamps wont raise when the lights are turned on, the wipers are not working, the turn signals/hazard lamps aren't working, and I can't hear the fuel pump prime when the key is turned on. I tried jumpering the ignition switch and it still would not start... I have a push button start on it and it turns the motor over but as I said before... No fire at the coil or plugs. Please help!!
Tricky3D is offline   Reply With Quote
Old Mar 16th, 2005, 05:28 PM   #2 (permalink)
bridrive55
KA24DET
bridrive55's Avatar
Send a message via AIM to bridrive55
Have you replaced the igniter chip?
StreetTech S13
KA24DET, .70A/R T04E, FMIC, VLSD, SAFC-II, 550cc's, Q45 MAF.
bridrive55 is offline   Reply With Quote
Old Mar 17th, 2005, 06:42 AM   #3 (permalink)
Tricky3D
Where is it?
Is it inside the distributor? I have not replaced it if so.
Where can I get one?
Old Mar 17th, 2005, 07:36 AM   #4 (permalink)
Blinocac200sx
Send a message via AIM to Blinocac200sx
I'd actually suggest checking the coil.
Blinocac200sx is offline   Reply With Quote
Old Apr 11th, 2005, 03:14 PM   #5 (permalink)
Farley_420
And igntion module
Farley_420 is offline   Reply With Quote
Intermittent (no) starting problem Actionclaw S13 240SX 1989-1994 14 Feb 9th, 2006 08:33 AM
94 XE not starting ojg GA16DE 1.6L Engine 8 Jun 3rd, 2004 04:47 PM
Rear Brake Problem 98 Sentra XE fr33kachu Suspension & Brakes 6 Aug 23rd, 2003 07:06 PM
My Theory on the infamous B12 Starting problem... LittlebittaContact B11/B12/KN13 82-90 chassis 6 Jan 8th, 2003 08:34 AM
funny convo!.. hope you... Niss200SXGTR Off Topic 6 Jul 4th, 2002 12:18 AM
