all of the above replies are right. you can do anything with enough money, but i'm sure that if you have a 13 year old car you're not exactly rich. my suggestion would be the sr20det simply because of ease, cost and aftermarket support. the ca18 is slightly easier since it was designed for the same engine bay as the ka24e, but the only problems you should run into with the sr20 is that you'll need a twin cam' power steering and ac compressor(if you want those to work that is). the rb 25 or 26 will make a lot more power, but it will require a lot of custom work and is a rather expensive engine any way. besides, the sr20 will easily produce 500+hp and is much lighter. besides, do you really need 1000 hp?
KA=Kick Ass
SR='S'all Right...
RB=Righteously Bitchin'
