Links
Go Back   NissanForums.com > Nissan Models > 240SX/Silvia/S12 200SX > General 240SX/Silvia/S12 200SX
General 240SX/Silvia/S12 200SX For general 240SX/Silvia/S12 200SX discussion
Old Apr 17th, 2008, 11:03 PM   #1 (permalink)
thcfankelsey
Ignition help
I have a 1989 240sx. Trying to change out the ignition switch, but cannot remove the old one to put the new one on. Could someone please explain how to remove it?
thcfankelsey is offline   Reply With Quote
Old Apr 20th, 2008, 01:50 PM   #2 (permalink)
rogoman
Super Moderator
To remove the ignition switch, you'll first need to remove the steering wheel. The combination switch then needs to be removed. Unplug the ignition switch harness connector. There should be two shear bolts that hold the ignition switch; remove these. That should do it.
KA > SR anyday of the week.
