Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > General 240SX/Silvia/S12 200SX
General 240SX/Silvia/S12 200SX For general 240SX/Silvia/S12 200SX discussion
Old Dec 13th, 2007, 07:21 PM   #1 (permalink)
jorgee
ENGINE STUCK..S12
Yo..i just got a 1986 nissan 200sx s12..when i got it the starter was disconected so i connected it and triesd starting it but it wouldnt..i just made a click sound...im thinking the engine is stuck from sitting so many years or???? dont know? i need help!
jorgee is offline   Reply With Quote
Old Dec 14th, 2007, 03:16 PM   #2 (permalink)
s12(20e)
s12(20e)'s Avatar
maybe the starter is just bad considering it was already off. Or ur car just aint gettin enough juice from ur battery if u havent put a new on in or charged it. But.......if u have done all that an it still doesnt want too then u might have to look into it deeper, from things like wires,soleniods,fuses ect..... ect. well wish ya luck.
s12(20e) is offline   Reply With Quote
Old Dec 14th, 2007, 07:30 PM   #3 (permalink)
jorgee
yea i tried 3 different batt..and the starter sounds likes its trying to turn but it wont budge...but thanks ill keep trying
Old Dec 15th, 2007, 01:01 AM   #4 (permalink)
s12(20e)
s12(20e)'s Avatar
have u tried goin to a local auto store an get the starter check? if not i suggest u do a port an polish on the engine only if urs comes with a ca18det cause the ca20 aint really dependable on the connecting rod side very very thin. plus look on the bright side, at least ull have a clean motor with alilttle more hp then stock. well fill me in on ur ride an how its goin cause im tryin to get my 84 ca20e project goin.
Old Jan 3rd, 2008, 03:40 PM   #5 (permalink)
sakeadorwify
HELLO IM SORRY BUT I DONT KNOW MUCH INGLES.
PROBLEM:The CAR MAKES CONTACT WITH ENEMY BUT DOES NOT MOVE OR MOVE LITTLE ?
SOLUCION1:The BATTERY FOR The FJ20E IS OF 70 Or 75 AMPERES. LESS AMPERES DO NOT GO. IT VERIFIES!
sakeadorwify is offline   Reply With Quote
Old Jan 12th, 2008, 11:16 PM   #6 (permalink)
OchnofConcrete
Nissan Fanatic
OchnofConcrete's Avatar
Send a message via AIM to OchnofConcrete
*snicker* make contact with enemy?...
anyways don't forget to check the resistance on the positive and negative cable, get rid of any corrosion.... engine harness continuity, good grounds, fuses, relays, ...take multimeter and check all engine sensors especially the *i don't know the s12 at all so i'm guessing at this part* the throttle position sensor and the crank position sensor on the distributor *again i don't know the s12 so i dont even know if ya got one* and check the ECU *the pins* for good ground and good positive circuits. but if this car sat for a long time... the oil needs to be checked for anything other than OIL. as old as the car is... though i had a 87 dodge truck back in 01... if there's stuff in the oil small enough to get past the oil strainer, you're gonna have stuff getting into the crank and piston bearings and camshaft journals, maybe even clogging them. another thing is that when a engine sits for a LOOOONG time the oil drains from the bearings and you need to completely disassemble the engine to be able to preoil the bearings...at least that's what i've heard. hell, might even be "stuck" where the bearings are from years of no oil. either way, i wouldn't chance it if it's sat dead for a long time. i've started up old cars before and they can start right up after fixing something small like a starter or something else, but engine seals and other stuff might keep oil from getting to where it needs to be so you're chancing it by driving something that old before making it "new" again.
dblclutchn lik a mofo, save me that clutch
damn government and their incredibly expensive tickets, hows a good natured racer supposed to stay legit?
gd... if i could only make it past the lower class, i'd be rich. damn facists.
OchnofConcrete is offline   Reply With Quote
what do i need 240sxhead General 240SX/Silvia/S12 200SX 4 Apr 14th, 2008 09:03 PM
engine flush vs Bilstein Engine Flush vs not at all ak47m203 Off Topic 7 Feb 21st, 2008 03:06 PM
GT-R Engine details revealed ak47m203 2008+ Nissan GT-R 0 Sep 14th, 2007 12:12 PM
Need Advice on Engine repair meesh L30 1998-2001 Altima 7 Nov 12th, 2005 01:21 AM
95 hardbody engine swap... eyeshyed Truck & SUV 5 Jul 6th, 2004 11:25 PM
