Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > General 240SX/Silvia/S12 200SX
General 240SX/Silvia/S12 200SX For general 240SX/Silvia/S12 200SX discussion
Old Dec 11th, 2007, 02:00 PM   #1 (permalink)
benmarkle99
starting problem
hey, i m having this problem that only happens once in awhile but its kind of annoying. sometimes when i go to start the car, its a 1990 240sx by the way, it doesnt even try and start the engine. Its almost like when you have the car in drive(its an auto) and try and start it. i can hear the fuel pump click but it just wont turn the engine. then i take the key out give it a second and try and it will work after a couple tries. It normally starts up fine otherwise its just the odd time this will happen...
thanks
benmarkle99 is offline   Reply With Quote
Old Dec 11th, 2007, 02:11 PM   #2 (permalink)
Nismo240
i'm an asshole
Nismo240's Avatar
Send a message via AIM to Nismo240 Send a message via Yahoo to Nismo240
starter could be going bad. i had similar problems when mine was going out.
Nismo240 is offline   Reply With Quote
Old Dec 11th, 2007, 02:31 PM   #3 (permalink)
benmarkle99
well that sucks
thanks
Old Dec 15th, 2007, 08:38 PM   #4 (permalink)
Kyu-ju-kue
Location: Japan, but not in that part ...no, not quite there either. A little more to the left of there.
Did you check your ignition sw? The plug on the back of it could be loose or broken.
Kyu-ju-kue is offline   Reply With Quote
Old Dec 15th, 2007, 10:24 PM   #5 (permalink)
thezman
look first for corrosion on the battery terminals its a very annoying problem and often overlooked, take them off and check the contact surfaces for the white crusties even if they look fine from the outside it only takes a minute to do/clean and eliminates a possibility. then check starter please keep us updated.
Towing broke down cars since 1999. Including primary for local Nissan, chevy, kia, Honda, dealerships.
thezman is offline   Reply With Quote
Random starting problem.. Chasity J30 1989-1994 Chassis 2 Feb 25th, 2008 03:45 PM
Starting problem with AC on; AC cuts out. fleck B13 91-94 chassis 3 Aug 27th, 2007 01:52 AM
1993 maxima starting problem rbalan J30 1989-1994 Chassis 2 Jun 9th, 2005 05:53 PM
Freeze Starting Problem with GA16DE 1.6 georgyop GA16DE 1.6L Engine 8 Jan 11th, 2005 07:58 PM
95 Sentra starting problem. davmil GA16DE 1.6L Engine 6 Feb 12th, 2004 05:30 PM
