Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > General 240SX/Silvia/S12 200SX
General 240SX/Silvia/S12 200SX For general 240SX/Silvia/S12 200SX discussion
Old Dec 1st, 2007, 09:18 AM   #1 (permalink)
Chozen
Question about running two fuel pumps in series
I am running an Aeromotive inline fuel pump that is installed underneath my car and I want to change the stock in tank one to a WalbroWalbro will flow 520 lbs/hr @ 13.5 volts and 45 psi, the Aeromotive I have will flow 325 lbs/hr @ the same 13.5 volts and 45 psi. So, the Walbro in the tank flows more fuel, while the Aeromotive downstream of that flows less. Does this mean that my fuel can only flow as much as the Aeromotive, or does this mean I will get more flow than the Walbro by itself?
built not bought.
Chozen is offline   Reply With Quote
Old Dec 1st, 2007, 10:20 AM   #2 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
Send a message via AIM to trmn8r
good question. i would probably look at it like a pressure washer you have faucet water. then the pressure washer has like 3 seperate water compressors. i goes to one, then the second give that pressure more boost, then the third gives it max pressure. now im not sure if that principal works with the fuel pumps. i would have to search some more. if i find something ill post it
Quote of the Day From Our Shop "Quick, ill wiggle it while you tug on it"
trmn8r is offline   Reply With Quote
Old Dec 1st, 2007, 12:11 PM   #3 (permalink)
rogoman
Super Moderator
rogoman's Avatar
If you install the pumps in series, the fuel pressure will rise well beyond 45 psi which is something that you don't want.
Install the pumps in parallel; this will maintain the pressure at 45 psi and will combine the volume output of each pump. However the size of the lines should be increased to take advantage of the increased volume.
Old Dec 1st, 2007, 01:32 PM   #4 (permalink)
Chozen
Thanks. I'll probably just delete the Aeromotive and install the Walbro in the tank then.
built not bought.
Old Dec 1st, 2007, 07:39 PM   #5 (permalink)
Kyu-ju-kue
Location: Japan, but not in that part ...no, not quite there either. A little more to the left of there.
I'm low on sleep and might be thinking about this wrong, but if 2 suppliers are connected to a receiver, won't the receiver catch the total applied amount from both suppliers making the end result 90psi, and if you have 1 supplier supplying another supplier which then supplies the receiver, the psi will be a better regulated 45psi?
Basically what I’m saying is if you were trying to fill a bath tub, if you used the sink faucet(45psi) along with the bath tub faucet(45psi) wouldn’t the tub fill faster due to the increased volume(90psi)?
If he installed a regulator that’s adjustable from 0-90psi, he won’t have to worry about over pressurization …at least to the engine anyway.
Kyu-ju-kue is offline   Reply With Quote
Old Dec 1st, 2007, 08:06 PM   #6 (permalink)
Asleep
Super Mod - ALL the time!
Asleep's Avatar
Send a message via AIM to Asleep Send a message via Yahoo to Asleep
not in a series though. in my head, unless im not visualizing this right because im on tramadol for back pain right now, lol, im picturing it as if its like running a smaller hose into a bigger hose. one of them is going to be a restriction, right?
Nissan Moderators needed
contact Sassan @ www.SUPERNISSANS.net
Asleep is offline   Reply With Quote
Old Dec 2nd, 2007, 09:07 PM   #7 (permalink)
Kyu-ju-kue
The big hose will have more fluid at a lower psi, if it supplies the smaller tube the volume will go down, but the psi will increase. A smaller hose to a bigger hose will be the opposite.
Can someone clearify this a little more?
Question about the Fuel System edwin84 QG18 1.8L Engine 0 Oct 7th, 2006 02:40 AM
91 NX1600 dies while running then wont start for 2 days, then starts and runs fine triplefour B13 91-94 chassis 0 Sep 16th, 2006 05:11 PM
swapping in tank fuel pumps FoxHole 4x4 and Off Road Action 4 Dec 31st, 2005 05:57 PM
maybe this can be added to the nitrous sticky? buffdaddy18 Forced Induction & Nitrous Oxide 4 Dec 15th, 2005 08:20 PM
Good source for fuel pumps sajohnson SR-Series Engines (DE/VE) 0 Sep 17th, 2005 12:48 AM
