Old Mar 4th, 2005, 11:37 PM   #1 (permalink)
B14_Stealth
new motor & tranny
B14_Stealth's Avatar
Send a message via AIM to B14_Stealth
Could engine itself drain too much power and kill the alternator?
Ok here is the deal, i blew my engine about like 2 weeks ago. I had to car towed and another used engine put in. Now here is the problem... the car was driving fine from the shop to my house, I drove it around like the whole day and at the end of it (at night) i noticed that my lights were dim. I looked at my voltometer gaugue and noticed that the voltage was only about 10v. My other gaugue..the air-fuel was going crazy. I went home and tested the alternator and the battery, only about 9.8v.
At that moment i knew something was wrong plus i could smell something burning from the alternator. I went to a shop and get the alternator replaced and they told me that the old one was fried.
Going home the gauge was indicating 14.1v which was perfect, after like 30 minutes of driving the voltage dropped to 12v. At that moment i started freaking out cause it was a new alternator.
I went back to the shop and they tested it for draws (shorts). They said that my system was the one that caused it. Before the new engine, I've had the same system setup, nothing changed, and it was working fine for 4 months so I can't belive that it might be the problem.
Anyway the mechanic told me to drive around for few days and see if it improves, well it didn't. The car died and had to get a new battery to get the car back to the shop.
My question is... is it possible for the engine itself to drain too much power which might cause the alternator to die?
Ill be picking up the car tomorrow with another new alternator. For at least like a week or 10 days I won't connect the system (I won't connect the power wire going to the battery). If the alternator problem happens again, then I know it was not my system and infact there is something wrong with the engine.
The used engine came with the 6 month warranty but the guy who did just went on vacation and won't be back for the next 10 days
B14_Stealth is offline   Reply With Quote
Old Mar 5th, 2005, 12:15 AM   #2 (permalink)
Tavel
Destroyer of worlds.
Tavel's Avatar
Send a message via AIM to Tavel
i dont think the engine could do that...perhaps something else? like improper wiring during engine install? but you'd have to have the guy look at it again.
I'll edit YOUR signiture!
Tavel is offline   Reply With Quote
Old Mar 5th, 2005, 12:34 AM   #3 (permalink)
B14_Stealth
new motor & tranny
thats a possibility....but i wonder if there is anything else besides the wiring
Old Mar 5th, 2005, 12:40 AM   #4 (permalink)
Tavel
Tavel's Avatar
maybe the coil, but it'd have to be drawing a ton of extra current to kill an alty that fast.
Old Mar 6th, 2005, 11:17 AM   #5 (permalink)
Nismo1997
Drop-Out
Nismo1997's Avatar
Send a message via AIM to Nismo1997
Did they put on new belts? Maybe its worn out or then put the belt on too tight.
I would check out the condition of the belt, check over the wiring going/leaving the altinator. How is your connection to the battery?
Nismo1997 is offline   Reply With Quote
Old Mar 6th, 2005, 07:28 PM   #6 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
Also check your ground wire to the block. All the other grounds too....lol
Nostrodomas is offline   Reply With Quote
Old Mar 6th, 2005, 08:36 PM   #7 (permalink)
B14_Stealth
new motor & tranny
yes they did change the belts
Old Mar 6th, 2005, 08:44 PM   #8 (permalink)
B14_Stealth
new motor & tranny
would bad ground fry an alternator?
Old Mar 7th, 2005, 11:42 PM   #9 (permalink)
B14_Stealth
new motor & tranny
so...3 alternators later.. im still having this problem. Im getting sick of driving the car back and forth to the shop so Ill just wait till the mechanic (from another shop) that swapped my engine comes back from vacation and let him have fun with it (6 month warrany, and the car didn't have these problems with the old engine)
Plus..my system this time (with the new alternator that i just got today) wasn't even connected and the alternator dropped charging to like 11.8v in about 30 minutes since i got it. I tested it before i left the shop it was about 14.4v (above 14 non stop) and the mechanics tested it too. Drove it home for about 30 minutes...went to check the charge and same thing as before. I could also smell something burning so there is deffinitely a short.
VQ35DE in a S13??? toddk S13 240SX 1989-1994 68 Dec 31st, 2007 10:55 PM
Didnt know where to go. Engine swap on 1983 280ZX hsvblondie428 General Z Discussion 11 Jan 4th, 2005 07:23 AM
Converting a VG30 engine to Fuel Injection MrBadExample Truck & SUV 1 May 15th, 2004 10:17 AM
New Engine , Same Knocking LUVMYTRUCK Truck & SUV 11 Jun 24th, 2003 01:14 PM
New Engine, Same Knocking LUVMYTRUCK New Member Forum 6 Jun 23rd, 2003 10:49 PM
