cut off is 6900
max in first is like 33-35 mph
second is like 60-63
third is around 90
no point of goin to cut off cause the power band sucks...unless u have b14 or JWT cams
01 Sentra SE/PP 5 speed, AEM CAI, ES MM inserts, ADV TMG :D
02 Maxima SE 6 Speed:) Cattman Exhaust, UR Pulley, PRI CAI, ADV TMG
04 Honda CBR 600RR Jardine CF exhaust, Greggs flush mounts, Puig screen, Competition Werks Rear Fender Eliminator Kit, Dr X Kit X-treme tail light
third is around 90
Ok, good info.... now... what difference are between the GA installed on my 1993 B13 and GA installed in a 1995+ B14 ? aren't they the same engine?
Originally posted by SergioCR Ok, good info.... now... what difference are between the GA installed on my 1993 B13 and GA installed in a 1995+ B14 ? aren't they the same engine?
first of all go to lcoal autozaone or pepboys and pick up a sunpro mini tach, it is only like 30$ and works good
B14 have different cams..they have a bit better top end, b13 have better low end
