» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Old Feb 8th, 2005, 04:09 PM   #1 (permalink)
Tek
Auto to Manual Swap w/ NX1600 guage cluster
I was wondering if this has been done before, and what I would need to get this going? (Obviously the donor car)
What ECU will I need (One from a sentra or one from the NX?), and suggestions?
I'm sorry if this has been posted before, but I searched and came up empty.
Thanks.
-Mike
Tek is offline   Reply With Quote
Old Feb 9th, 2005, 12:23 PM   #2 (permalink)
Nissan Addict
sunnysentra's Avatar
you will need the manual ECU for the year of your car. 92 auto needs a 92 manual and so forth.
You need to change the Air regulator under the plenum also for the manual unit. call Mossy for the part and tell him you are swapping the auto to a manual. make sure you tell him the Manual part. Your idle will be at 2-3000 rpm all the time if you don't change it out. Some hints from a Swapper club member.
Welcome to the swap club.
Chris 92 classic
Part of the AUTO / MANUAL SWAP CLUB
sunnysentra is offline   Reply With Quote
Old Feb 9th, 2005, 03:26 PM   #3 (permalink)
Tek
ok. That helps a lot. thank you.
But, along with that, I want to have the digital cluster for the NX1600 in there. I am not sure if the ECU for a manual 99 will work with it. I know that anything (with enough money) can be done. However, I don't have that kind of money and I want to know what I'm getting myself into before I start.
Old Feb 11th, 2005, 09:08 AM   #4 (permalink)
Nissan Fanatic
No, an ECU from a 99 will definitely not work. You have a OBD1 car and the 99 ECU is from an OBD2 car.
Get an ECU from a a 91-94 NX or Sentra, w/ manual trans. The ECU between a digital dash NX and analog dash are no different, the cluster is the difference.
1991 Sentra SE - Auto to Manual swap, 15" Rota Subzero's, 205/50 Kuhmo 712's, Tsuru headlight conversion, SE-R front and rear disc brakes, SE-R front and rear swaybars, SE-R throttle body, SE-R rear inner taillights, HS CAI and Header, H&R springs, Koni shortened struts, ES Hyperflex kit, B&M Short Shifter, Autometer gauges.
johnand is offline   Reply With Quote
Old Feb 11th, 2005, 03:16 PM   #5 (permalink)
Tek
ok. some confusion. I have a 99 sentra (GA16), and I want the digital dash from the NX. So, I still have to go with the NX ECU, or the sentra's?
Old Feb 11th, 2005, 05:27 PM   #6 (permalink)
Nissan Fanatic
Wow, you really fooled me with your unclear explaination of what you were trying to do. Now, it is so much clearer. The ECU and cluster don't care who's who. So, if you have a 1999, and you want a digital dash out of an early 90's NX, you are really in for some work. If you are doing the auto to manual swap, get a 1999 ECU out of a manual car. An NX ECU wouldn't work in your car anyway.
You are going to have to completely rewire your wiring behind the cluster to get the NX digital dash to work. Good luck, you'll need it
Old Feb 12th, 2005, 07:19 PM   #7 (permalink)
Tek
ok, well, if it be that much work, it's not worth it to me just to have an 'interesting looking' dash. Thanks again for the responses. Greatly helps.
S13 Auto ---> Manual **pics inside OPIUM S13 240SX 1989-1994 26 Mar 3rd, 2005 12:15 PM
What it costs to do an RB20 swap + auto --> manual OPIUM S13 240SX 1989-1994 10 Dec 9th, 2004 11:46 PM
Auto to Manual Swap Day. Looking for some help sentra97gxe New England/Mid Atlantic 72 Sep 21st, 2004 11:39 PM
91 nx2000 manual tranny swap into '93 auto G20? gettodanser General Discussion 1 May 1st, 2004 09:22 PM
Pics of my B13 auto to manual swap! johnand Member Rides 8 Oct 1st, 2002 02:24 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
