Old Jan 10th, 2005, 06:23 PM   #1 (permalink)
Startours7
Low coolent=no heat?
95 200sx se
GA16DE
5 speed
150,000mi
I tried to search
Ok this morning on the way to work my car started and warmed up fine but the heat didn't come on. When I stepped on it the heat came on but slowly faded back to cold.
At lunch, the same thing happened but the car started to over heat. Pulled over and the rad. level was low. Filled it up and bam. Heater works fine and car wont over heat.
WTF?
Would a low coolent level make the heater not work? Like not enuff coolent going through the heater core?
Oil and coolent look fine. No puddles on the carpet. Hoses look/feel good.
Thank you.
Dave
92' 240SX
95' XE-V6
87' Power Ram 250
Nissan never made a 240sx hatchback.
Startours7 is offline   Reply With Quote
Old Jan 10th, 2005, 06:57 PM   #2 (permalink)
SoCalB14
If you got no coolant to pump, then it will not cool down the engine and warm you up. If you are really low, the coolant will be below the water pump, and it doesn't go anywhere.
Now the question is.....Why it got low, and where it went? The cooling system is a sealed system. You should not have to add much fluid during normal use. Check to see that your water pump is not dying. If it is leaking coolant out the weep hole, then it's bad and needs to be replaced.
1995 200SX GA16DE, 4sp Auto
1994 Camaro Z28, LT1, 4.10's, T56, 13.2@110
1994 Camaro Z28, LT1, 3.23's, 4L60E
1997 S10, EcoCrap 2.2L, NV1500, 3.73's
SoCalB14 is offline   Reply With Quote
Old Jan 10th, 2005, 07:29 PM   #3 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
The heater uses the hot water to heat up the air being blown in from the fan.
Nostrodomas is offline   Reply With Quote
Old Jan 11th, 2005, 02:38 PM   #4 (permalink)
jer28
Nissan Fanatic
Borrow a coolant pressure tester from someone. Or you can have the system pressure tested. That way if the water pump is bad it will immediatly come out the weep hole in the water pump (as mentioned). Also if you haven't done a coolant change it sounds like now would be a great time for a flush/thermostat/refill. Be sure to remove all the air when you do this, you probally still have some air in your system now. As it was also mentioned the cooling system is a closed loop system......
jer28 is offline   Reply With Quote
Old Jan 11th, 2005, 05:12 PM   #5 (permalink)
Startours7
Thanks.
After thinking about it, it made sence.
It's been raining for a few days so when it drys up I can check it out. I have been keeping a good eye on the coolent level and it's not going down.
Thank you again.
92' 240SX
95' XE-V6
87' Power Ram 250
Old Jan 12th, 2005, 10:04 AM   #6 (permalink)
Jed118
Jed118's Avatar
Send a message via MSN to Jed118
heh I know I had to change mine because it leaked out of that hole in the water pump. I'd fill it up and 30 mins later there'd be a puddle of coolant. I found where it was coming from... I was not happy about that, it wasn't easy to change either.
1993 Sentra GXE - Non stock parts (I dare not call them "mods") 2 inch NX downpipe to cat, hiflow cat, 2002 Sunfire GT right muffler, NX2000 rear disc brakes.
Coming very soon : Digital NX cluster, LED voltometer, Fog lamps. Go automatic GA16DE!! :rolleyes:
Jed118 is offline   Reply With Quote
Old Jan 12th, 2005, 11:57 AM   #7 (permalink)
Startours7
It's the water pump.
Good thing the rain stopped.
It's a beutiful day in San Diego to change a water pump.
Is there anything I should check for damage from the pump leaking?
Thank you,
Dave
92' 240SX
95' XE-V6
87' Power Ram 250
Old Jan 12th, 2005, 12:05 PM   #8 (permalink)
I'm tired of my usernamee
Soggy GloryHoler
I'm tired of my usernamee's Avatar
Send a message via MSN to I'm tired of my usernamee
Thank you,
Dave
make sure that you clean the gasket material off the block and clean it real good, then just put the new one on and use new ahigh temp sealant but let it cure for 24 hours
Originally Posted by mzanubis
yeah yeah yeah, the important question is... can it reheat my burrito?
www.nissanpacific.com
I'm tired of my usernamee is offline   Reply With Quote
Faq About Sr20ve LIUSPEED SR-Series Engines (DE/VE) 34 Feb 14th, 2008 01:21 PM
OBD II Code Chart no1see2me QG18 1.8L Engine 7 Oct 21st, 2006 12:36 PM
Low Octain faster burn = Heat? sentravis General Discussion 47 Nov 22nd, 2003 04:50 PM
turbo heat wrap mtcookson Forced Induction & Nitrous Oxide 37 Aug 25th, 2003 01:58 AM
