Wheel Bearing Lock Nut Q - Nissan Forum
post #1 of 10 Old Dec 28th, 2004, 12:42 AM Thread Starter
NF SUX DIK
Boromir's Avatar
Angry Wheel Bearing Lock Nut Q
i searched and found no straight answer.
im trying to install my driver side axle on my 95 auto sentra. the b**ch had to pause because i dont have big enough socket for the nut thats in the middle of the wheel bearing/rotor.... what size is that? do i need 1/2 inch wrench? i just got basic wrenches.
those are the steps, correct me if wrong:
-take wheel off
-remove the little pin
-remove struts monting bolts
-separate the wheel bearing from the axle
-yank the axle out gently
Thank you.
Big Boss
Boromir is offline
post #2 of 10 Old Dec 28th, 2004, 12:47 AM
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
you will need a 1/2 ratchet and use a 32mm deep socket
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline
post #3 of 10 Old Dec 28th, 2004, 12:52 AM Thread Starter
NF SUX DIK
Boromir's Avatar
i didnt expect anyone reply that fast.. thanx bro.
Boromir is offline
post #4 of 10 Old Dec 28th, 2004, 12:57 AM
My ass, your face
haha, yea, no prob.
this is how i typically do it
1. remove centercap off wheel
2. remove cotter pin from axle
3. remove axle nut with 32mm socket
4. remove wheel
5. loosen strut bolts (17mm)
6. ease axle out gently
the reason i take the axle nut off before anything is because it is usually on pretty tight and once the car is on jackstands..trying to loosen it up becomes hard(even if you have someone else hit the brakes) because it is usually torqued down pretty bad and all you end up doing is spinning the spindle which gets you nowhere. hope that helps
post #5 of 10 Old Dec 28th, 2004, 01:20 AM Thread Starter
NF SUX DIK
Boromir's Avatar
so you saying after step 3 (your steps) i should jack the car up, right?
Boromir is offline
post #6 of 10 Old Dec 28th, 2004, 01:23 AM
My ass, your face
correct....with the wheel on the ground..remove the axle nut and once its loose. raise the car and remove the wheel
post #7 of 10 Old Dec 28th, 2004, 01:28 AM Thread Starter
NF SUX DIK
Boromir's Avatar
and while taking the nut off, should someone step on the brake pedals? what do u reccomend
Boromir is offline
post #8 of 10 Old Dec 28th, 2004, 01:33 AM
My ass, your face
if the wheel is on the ground, no one needs to step on the brakes...just as long as the e-brake is engaged, u should be fine.
post #9 of 10 Old Dec 28th, 2004, 01:36 AM Thread Starter
NF SUX DIK
Boromir's Avatar
nice, i think it will be easy then. ive seen it done once.. now since im at it, down and dirty..im tying to find a way to do tire rotation at home...its puzzling..any ideas? i got 2 jack stands, 2 ramps and lotta cylender blocks... hmmm is it really important to use a TQ wrench when mounting tires?
Boromir is offline
post #10 of 10 Old Dec 28th, 2004, 03:37 AM
absolutely classic
Kindfiend's Avatar
pick up 2 more jackstands. You got four corners to work with. And yes, it's important to use a torque wrench when mounting the tires. Unless you want to break a hub bolt, and I don't think I would ride to the auto parts store with just 3 nuts holding a tire on there.
Kindfiend
01 Sentra GXE
92 SE-R
Kindfiend is offline
Gear in this thread - nissan wheel by PriceGrabber.com
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
rear wheel bearing gccch A32 1995-1999 Chassis 0 Sep 27th, 2004 09:26 PM
URGENT HELP NEEDED: How to get rear backing plate and wheel bearing off 89 Hardbody? Wagon Wagon Truck & SUV 3 Aug 27th, 2004 08:15 PM
Wheel Bearing Lock Nut Socket jadcock Truck & SUV 10 Jun 15th, 2004 12:50 PM
Wheel Bearing Help. HuMMerMan B11/B12/KN13 82-90 chassis 7 May 2nd, 2003 09:38 PM
Wheel bearing or hub bearing... dschrier B11/B12/KN13 82-90 chassis 5 Oct 20th, 2002 10:34 PM
You may post new threads
You may post replies
BB code is On
